Mystery water leak . . .
Can't seem to locate a leak I have. It's on the passenger side and the sloshing noise comes from the dash area.
Is there a void between the firewall and the passenger compartment that could be taking on water from a small leak?
Any other thoughts on how I can troubleshoot this issue? Big mystery that needs a solution.
Thanks in advance!
Old 01-23-2003, 10:34 PM
AFJuvat's Avatar
Sounds like the drain line from the evaporator is clogged. Water tends to gather there. If you look under the car on the passenger side near the firewall, you should see the drain. use a thin wire to upen it up again.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-24-2003, 03:29 AM
Is that the "hard plastic" black tube that come from the AC to dump condensation when running the AC or is it another drain.
All the drains with the black flaps have been cleared and I can't seem to rind any other small drain.
Thanks in advance for any advice you can provide!
Chuck
Old 01-25-2003, 01:54 PM
ReZ ReZ is offline
ReZ's Avatar
I have a leak where the right back side of the sunroof is. Is there a water drain for the sunroof? I was thinking fo resealing the sunroof....
It's all about the corners!
http://www.calinetworks.net/rez/redt2/7n914pictar.gif
-1985.5 944 (late)
-1974 914
-1990 RX7 TII
Old 01-25-2003, 10:43 PM
ReZ, Yes there are two drains on the rear side of the sunroof gutter. these can often come loose get clogged or even crimped. Any of the three could cause your problem. You can poke something down the drain holes and see if it drains out( under the body in front of the rear wheel wells If I recall correctly.
Be carefull putting anything too rigid down the sunroof drain tube. One can push the tube itself down into the body..not fun! It is best to use heavy guage plastic wire like that found on a weed eater.
Good Luck
Ross T
Old 01-26-2003, 01:04 AM
Roger Hall's Avatar
On mine the suroof drain tubes run out behind the rear wheels.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 01-26-2003, 09:33 AM
