-   -   Piston Scuffing (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/960603-piston-scuffing.html)
M1Jenkins 06-18-2017 09:21 AM
Piston Scuffing
I’m in the home stretch of my timing belt failure rebuild. I have taken off the cylinder head and am cleaning the carbon deposits off the pistons. Once clean I notched some scuffing on the top. I’m unsure on what the tolerances are on these, would these work fine or are they too damaged?http://forums.pelicanparts.com/uploa...1497806409.jpg
http://forums.pelicanparts.com/uploa...1497806425.jpg
v2rocket_aka944 06-18-2017 09:26 AM
maybe a light touch of sandpaper to smooth it down but i wouldnt worry about it.
DannoXYZ 06-18-2017 01:40 PM
Or use deburring tool on the sharp edges. Then sand the edges and edges of other valve pocket.
This improves heat dissipation and knock-resistance
dgcantrell 06-19-2017 05:25 AM
yeah. As long as the edges are smoothed and nothing gnarly sticking up, it should be fine like the others say.
