I’m in the home stretch of my timing belt failure rebuild. I have taken off the cylinder head and am cleaning the carbon deposits off the pistons. Once clean I notched some scuffing on the top. I’m unsure on what the tolerances are on these, would these work fine or are they too damaged?
maybe a light touch of sandpaper to smooth it down but i wouldnt worry about it.
Or use deburring tool on the sharp edges. Then sand the edges and edges of other valve pocket.
This improves heat dissipation and knock-resistance |
yeah. As long as the edges are smoothed and nothing gnarly sticking up, it should be fine like the others say.
87 944N/A since 1992 87 944S - Near Future Engine Project Car 88 944S - Current Project 84 928S - Restoration Project |
Tags |
block , cylinder head , piston , rebuild , timing belt |
