-   -   944 trailing arm (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/96148-944-trailing-arm.html)
helowrench 01-29-2003 07:30 AM
944 trailing arm
I am about to help a friend change the rear wheel bearings. While we have the trailing arm off, what else would it be "the perfect time" to change also? like shocks/bushings/etc?
thanks everyone
Rob
78 924 na
82 280zx na
SoCal Driver 01-29-2003 10:06 AM
Timing belt.
helowrench 01-29-2003 06:06 PM
I am talking about other stuff under the rear in the vicinity of the trailing arm that are easier to deal with when the trailing arm is out of the way.
thanks
AFJuvat 01-29-2003 06:49 PM
rear bearing, seals, brake hoses, clean/regrease cvs. may consider turning the rotors while you hace them off
hint: if you are going to heat up the hub to install the bearings, remove the rotor first - otherwise it acts like a heat sink
AFJuvat
Scootin159 01-29-2003 07:41 PM
Originally posted by SoCal Driver
Timing belt.
I wonder how many posts you've made with those two words alone. Have you had one break on you?
