helowrench's Avatar
944 trailing arm
I am about to help a friend change the rear wheel bearings. While we have the trailing arm off, what else would it be "the perfect time" to change also? like shocks/bushings/etc?
thanks everyone
Rob
78 924 na
82 280zx na
Old 01-29-2003, 07:30 AM
SoCal Driver's Avatar
Timing belt.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-29-2003, 10:06 AM
helowrench's Avatar
I am talking about other stuff under the rear in the vicinity of the trailing arm that are easier to deal with when the trailing arm is out of the way.
thanks
Old 01-29-2003, 06:06 PM
AFJuvat's Avatar
rear bearing, seals, brake hoses, clean/regrease cvs. may consider turning the rotors while you hace them off
hint: if you are going to heat up the hub to install the bearings, remove the rotor first - otherwise it acts like a heat sink
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-29-2003, 06:49 PM
Rennlist Member :)
Scootin159's Avatar
Originally posted by SoCal Driver
Timing belt.
I wonder how many posts you've made with those two words alone. Have you had one break on you?
2006 Subaru Impreza WRX STI
1989 Red Devil F440
Former: 1987 Porsche 944
Old 01-29-2003, 07:41 PM
