-   -   Broken Turn Signal Switch (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/970899-broken-turn-signal-switch.html)
AC130Tron 09-19-2017 06:06 PM
I had to remove my steering wheel due to a broken weld on one of the spokes and have it repaired. I needed to replace the steering column bushing, so I removed the turn signal and wiper switches. After doing so, I noticed a thin metal part sticking out of the turn signal switch and it fell out of the switch. (For the photo, I reinserted it in the approximate position that I saw it before it fell out.) The switch will not operate and I have no idea if I can reinsert the part, as the switch housing is riveted and can’t be disassembled.
Any ideas?
http://forums.pelicanparts.com/uploa...1505869413.jpg
Dmitry at Pelican Parts 09-20-2017 10:54 AM
Hello - I'm attaching a link to an earlier thread where this is discussed - our members will likely chime in with assistance, but you may also want to add your question to the earlier thread and see if that generates a response from those who have already troubleshooted this. Hope this helps a bit and best of luck!
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/775831-944-turn-signal-issues.html
