1983 944
Broken Turn Signal Switch
I had to remove my steering wheel due to a broken weld on one of the spokes and have it repaired. I needed to replace the steering column bushing, so I removed the turn signal and wiper switches. After doing so, I noticed a thin metal part sticking out of the turn signal switch and it fell out of the switch. (For the photo, I reinserted it in the approximate position that I saw it before it fell out.) The switch will not operate and I have no idea if I can reinsert the part, as the switch housing is riveted and can’t be disassembled.
Any ideas?
Old 09-19-2017, 06:06 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hello - I'm attaching a link to an earlier thread where this is discussed - our members will likely chime in with assistance, but you may also want to add your question to the earlier thread and see if that generates a response from those who have already troubleshooted this. Hope this helps a bit and best of luck!
944 turn signal issues
Old 09-20-2017, 10:54 AM
