Unknown Brake pads 87 944S
Hello to all
Does anybody recognize the type of caliper that uses the brake pads pictured in this post ? Stock pads are the ones with openings in the middle with actual pads having larger holes on the outside.
I dont know what pads to purchase.
Thanks in advance
Pedro
Old 10-02-2017, 03:33 PM
racer's Avatar
Why not post a pic of the caliper? Maybe they are not OEM calipers or your new pads are wrong... From our host, here is what they should look like, as mentioned, like your "wider" hole example:
http://www.pelicanparts.com/catalog/SuperCat/0991/POR_0991_BRKPAD_pg1.htm
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 10-02-2017, 05:22 PM
In the Fires of Hell.....
kdjones2000's Avatar
Looks like you bought some pads for the S2.
The S has the same calipers as the NA, which look like your old ones in that picture.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 10-02-2017, 05:28 PM
Caliper pics
Does this help? Crappy pics i know but all i have at the moment
Old 10-02-2017, 09:00 PM
kevingross's Avatar
They sure look like pads used in the Brembo calipers on the original 944 Turbo (non-S) and 944S2, among other models.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 10-03-2017, 04:13 AM
Those are stock 944S/NA calipers. You should have some pins going through the holes to hold the pads in place, plus a wire keeper at the inside of the caliper.
Old 10-03-2017, 06:04 AM
Stock pads at least from autozone, do not match up to the calipers installed on my 944s
If stock pads wont work what my next choice? S2?
Old 10-03-2017, 01:35 PM
Lie to the idiot behind the Autozone counter and tell him that you have an 87 944 (not an S, not a turbo), and you should get the right pads.
That said, there are much better pads out there, probably cheaper.
Good luck, George Beuselinck
Old 10-03-2017, 01:50 PM
Return the autozone pads and buy Mintex pads here on Pelican for $30/axle.
Old 10-03-2017, 01:51 PM
Yes, second the Mintex pad idea. They are really good.
Neil
87 944S
http://guns.claasen.us/
Old 10-03-2017, 08:28 PM
Thanks guys!
Mintex pads have been ordered!
Old 10-06-2017, 10:49 AM
