88’ na icv
Does anyone have an ICV for an 88’ NA? $200 for one seems a bit steep. Not to mention everywhere iv checked is out of stock
Old 01-24-2018, 10:05 PM
Have 944, will restore
mazdaverx7's Avatar
May want to post a want to buy ad in the classifieds section. Browse through the part out threads and see what you come up with.
85.2 944 Guards Red M456 5spd
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary
04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd
84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE
Old 01-25-2018, 03:34 AM
Just get one for a Saab, Volvo, BMW, etc with the same connector and barb arrangement. They did not make a special one for Porsche. My 94 968 had a BMW E30 ISV in it when I got it. Worked fine but the fittings were wrong orientation.
Maybe something like this? Is yours 3 wire?
https://www.ebay.com/itm/New-Idle-Air-Control-Valve-IAC-Speed-Stabilizer-525-i-325-IS-323-CI-328-330-XI/191792062704
I'd probably get a good clean used Bosch one myself for similar money and clean up the grungy end with some acetone and ATF. Under $20 shipped by the pick-n-pull folks on Ebay.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 01-25-2018, 04:45 AM
Contact Mark at Plyhammer Parts
https://plyhammersparts.com/
Old 01-25-2018, 06:11 AM
Dimi 944's Avatar
I have one available. Sent me an email.
Dimi P
www.fhmotorsport.com
Porsche 944 $2
Porsche 944 Turbo - 968 power/drive train
Dimi Paralanov
Flying Horse Motorsport
flyinghorsemotorsport@gmail.com
Old 01-25-2018, 06:49 AM
Hi,
I had good luck, so far, with an ICV that I purchased directly from China. Search under the Bosch number (0280140501) in the usual places. Cost around $50.00.
I built a bench tester to test my original ICV. I couldn't get it work smoothly at all temperatures even after cleaning. Plus it was leaking a little. I wouldn't expect any used unit to work much better. They are all getting on thirty years old now and the wear patterns are all the same.
I got the unit form China as a stop-gap measure. It tested well on the bench and works well in my 86 944.
Last I checked, an ICV can be ordered from Porsche, if the cost is not an issue. Also, our host list the unit as in stock, ships tomorrow.
Peter
Old 01-25-2018, 08:33 PM
