Trying to keep my 944 roadworthy
I had a clicking coming from the transmission. Pulled the trans; found I had a cracked Flexplate and two different size axles. I am in search of a Flexplate #944.421.121.00.
The axle I need is approx 22" long. Does anyone have these parts? Thank you |
Have 944, will restore
It would help if you provided the year of your car.
85.2 944 Guards Red M456 5spd 85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd 84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary 04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd 84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE |
Common fix is to replace the troublesome rubber dampener with a regular clutch disc and pressure plate. Do a search.
Red 84 w/25,xxx miles Stone Gray 89 S2 w/90,xxx miles |
yes, you remove the auto flex plate (assuming you are referring to the rubber thing) at the engine-end and bolt on a good used manual flywheel, clutch disc and pressure plate.
no other clutch parts or pilot bearing required, all these parts serve to do is provide a solid connection between the crankshaft and the driveshaft. and yes the automatic uses different-length axles. |
For parts try John Grimes at "Just Joshin Porsche 944 Parts"
301-992-1912 or www.porsche944usedparts.com He's kept me on the road for years.
Red 84 w/25,xxx miles Stone Gray 89 S2 w/90,xxx miles Last edited by jhowell371; 03-10-2018 at 05:07 AM.. |
