Another dumb strut assembly question
I have on my car :
Stock original struts (Sachs)
Springs : 13mm diameter
I have in-hand strut assemblies, complete with bushing :
___ 500 100 640 (number obscured)
___ 500 100 639 (number illegible)
944.343.031.17
944.343.032.17
Weltmeister
SP-250
28/94
13 mm
... if I simply swap these, ... will the front end be the same height?
What else might happen?
Old 02-27-2018, 05:51 PM
9FF 9FF is offline
9FF's Avatar
Apologies but I cannot make out what your plans are from your post.
What car are these for?
Are you planning to replace the stock front struts with any of the ones you listed and then fit the SP-250 Welts? or
Are you planning to swap the stock springs on your existing stock struts with the SP-250 Welts?
What do you mean by “strut assemblies complete with bushings”? I don’t know of any “bushings” on any 944 strut assembly.
Generally the SP-250 Welts are designed to lower a stock ride height car by 1.25". How much your car will be lowered by fitting those springs will depend on how worn you current springs are.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 02-27-2018, 06:08 PM
9FF, thanks, and I do apologize for the haste.
Current in-service struts are worn, want to replace with better and used pair.
I have used Weltmeister-fitted struts - the whole thing is assembled, including the .. the ... strut mount (oh, that’s the term - sorry).
So bare minimum of work to remove and replace.
I am lost when it comes to ride height, and such - I just want normal, really...
Old 02-27-2018, 09:10 PM
‘87 944 na
Old 02-27-2018, 09:12 PM
9FF 9FF is offline
9FF's Avatar
They will be fine, the height may be slightly lower but it won’t look bad or affect anything. If it rakes too much at the front you can lower the rear slightly using the eccentric bolt before you get it all aligned.
Mike A
Old 02-28-2018, 03:36 AM
FWIW
here's a pic (below, the next comment) of the pair of used strut assemblies I have - I'd be interested to know the function of the spring, specifically, what the ... different number of coils per inch (?), at either end, is doing ...?.... on the same spring.
I'm warming up to do this...
87 944 NA
Old 03-17-2018, 09:03 AM
87 944 NA
Old 03-17-2018, 09:04 AM
That is a progressive rate spring. A linear rate spring will have the coils somewhat evenly spaced.
Ideally, the closer coils are on top of the assembly.
If you are removing the top strut mounts, inspect the bearing.
Old 03-18-2018, 10:05 AM
Coeur d'Alene, Idaho
Greast the upper bearing - just squash some fresh grease in with a popsicle stick but be sure you're not squashing dirt in also. Clean the seals first. You will need an alignment afterwards.
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback.
Old 03-18-2018, 07:14 PM
thomasryan, thanks - I did not know that, very interesting. what is the "rate" - vibration frequency per second? then a pothole will make a low frequency vibration, and a low-frequency (low rate) spring should be matched to the pothole frequency?
should I make a point to the spring put in the other way around then?
what's an OK-off-the-shelf-from-the-FLAPS grease for this - lithium?
87 944 NA
Old 03-19-2018, 07:29 AM
The rate in our specs is pounds per inch in this instance.
The work shop manual give the paint dot codes for the pounds per inch of OEM springs. A progressive rate spring might be 120 pounds for the first inch, 150 pounds/inch for the second inch then 180 pounds per inch for the third. Theoretically, progressive rate springs are more suitable for public streets where potholes abound.
Old 03-19-2018, 10:06 AM
I’m back again - some questions.
I got the Koni 8141-1414SPORT struts from Pelican - showing some love!...
Ahem... ‘87 944 NA.
1. Drilling the hole in the bottom of the original strut housing:
There’s a Koni cut a strut video [ https://youtu.be/PXSnNZt3NiI ] which says you need a 1/2” or 12mm drill bit. The instructions that come with the Koni inserts, labeled “1027 05 20 22 207/2”, say to cut a 14mm hole. There is a third piece of information from Koni [ http://www.koni-na.com/CorporateSite/media/itt/NA/pdf/boltstrut.pdf ] which says to use a 9/16” or 14mm drill bit.
The outer diameter of the threads on the bolt that comes with the Koni inserts is really really close to 12mm or 1/2” and so is the outer diameter of the threaded mating surface on the bottom of the strut insert that the bolt mates with.
Question is what diameter hole should be drilled into the old strut housing?
2. I have the Porsche bump stop - does this need to be cut? How would I know?
Let’s get that out of the way before I post some pics of what’s going on...
Oh, one more question :
3. The calculation of where to cut the original strut tube:
Printout from website says subtract 7mm. Instructions with the struts imply 6mm (“L1=46mm -> L2=40mm”).
87 944 NA
Old 09-02-2018, 10:11 AM
9FF 9FF is offline
9FF's Avatar
1. The reason for the varying online measurements for the hole is that Koni changed the bolt at one time. Just drill it sufficient to clear the supplied bolt.
2. Cut the Porsche bump stop and fit the Koni one, iirc they are different diameters anyway so the Porsche likely won’t fit the Koni insert.
3. 1mm isn’t going to make any difference.
Mike A
Old 09-02-2018, 11:57 AM
Lowering the 944 creates fender rubbing problems most aftermarket springs lower the ride height. If you want the same ride height then get new not used factory front springs after 30 years springs just sag.
Old 09-05-2018, 07:02 PM
