Windshield washer sprayer still not working on 924s
Recently my windshield washer sprayer stopped working and I immediately came to the conclusion that it must be the washer pump as that was previously an issue on the car. So I swapped in a new pump and to my stupidity nothing changed. I should have tested the old pump first before I ordered the new one as the old one worked fine when I hooked it up to 12 volts. When the windshield wiper stock is pulled to engage the pump, the wipers do there part no problem but no washer jets. I know nothing is clogged up as I don't even hear the pump engage. My question is what else might cause the washer pump to not work? I obviously don't have 12 volts at the pump and I know the relay is fine because the wipers still go so what next?
Old 02-22-2018, 06:15 PM
I literally just went through this tonight on my 924S. The activation switch on the wiper stalk by the steering wheel is a terrible design. Mine would activate the wipers but not the sprayers, and I could not get the contacts to make reliable electrical contact. There are TWO sets of contacts that have to work when you pull the stalk, and man is all that stuff flimsy!
I eventually just put a momentary rocker switch under the dash for my sprayer motor to activate it that way. Tired of messing with cheapo Volkswagen stuff.........
Also, according to my wiring diagram there is no relay for the washer pump - I think it's just a direct circuit since it's fairly low amperage. So either it's a bad pump, a bad switch on the stalk, or the wiring or ground is bad. Nothing else could cause it.
Old 02-22-2018, 06:56 PM
Thanks I'm glad I'm not the only one who has had this problem. Could you tell me what goes in to removing the wiper stock? I've removed the steering wheel before but have never had the need to look at any of the stocks.
Old 02-22-2018, 10:52 PM
basically you just take out the three little screws on the face of the assembly, and unplug everything, and you should be able to get it out (there are little side clips on the plastic covers too).
Also, on my original issue....the Mk2 Jetta/Golf washers do not fit....way smaller than they look in photos
Old 02-27-2018, 03:50 PM
Tired Member
DaddyGlenn's Avatar
Just did this in January for my son's 944. Assuming the switch is the same, one you pull the steering wheel, you can slide a piece of sandpaper in to clean the contacts and if needed you can give them a little bend. Quick and easy fix.
P.S. I, too, now have a brand new pump sitting on the shelf.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 03-04-2018, 03:00 PM
After much intermittent issues with this, I just hooked the pump to a momentary rocker switch and mounted it under the dash on the side of the center console. Easy access, no more failures
Old 03-05-2018, 05:49 PM
