stray15's Avatar
Send a message via AIM to stray15
Unhappy She left me sit....HELP
I finally have a techinical post. Sadly...
I'll make this short since I'm in a hurry...
Car was driven slowly through standing water. It was fine for a few miles then when I started to speed up and at about 2k rpm's it started getting really rough and started to buck. I slowed down and it was fine. So I try again and it does the same thing. I come to an intersection and as I stop the car dies. I try to start it and it doesn't start. I look under the hood to see all the electrical stuff by the headlight motor all wet.
I'm guessing that I got one of the components wet. Which one would most likely gotten wet?
Do you think that if I let it sit for a few hours it will eventually dry it self?
Or should I start pulling the parts, drive home and try to dry them with a hair dryer or something?
I'm stuck somewhere that I can't stay very long so I need answers as soon as you can give them please.
I would just like to thank the person that finally stopped and helped me push my car off the road.
Another 944 even passed me...he did wave though...I would have at least stopped...I guess he was in a hurry.
Old 02-24-2003, 06:16 AM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
distributor and rotor, wires plugs.. dry em..!!!
maybe replace the plugs..
My car is naughty
Old 02-24-2003, 06:37 AM
Sternn's Avatar
Wet distributor cap. Wait and it will start up. I have seen then take a few hours to dry out though.
-S
- Sternn
- 944S - Project Car
- Web Master & Used Part Guru From
- www.stuttgartparthaus.com
Old 02-24-2003, 07:04 AM
afx afx is offline
afx's Avatar
Send a message via ICQ to afx
not sure if you have an NA or not, but if you do check the air box. do you have it getting air from the dirvers fender area? If so you may have sucked up some water. I did this in my old 944 and the air filter was soaked and there was a bit of water in the bottom of the air box. My car was running really rough, but it eventually got better after some drying out.
85.5 Red 944
Http://members.rennlist.com/afx
Old 02-24-2003, 07:09 AM
AFJuvat's Avatar
Pull and dry wires, and dizzy cap, check the airbox.
944 engines hate water.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 02-24-2003, 07:16 AM
stray15's Avatar
Well I went back to the stop with my tools and I didn't need them.
When and tried to start her and she fired right up. I moved the car to a parking lot and thats where she sits.
Thanks for reading guys and trying to help!
Maybe I'll change the cap, rotor, and coil soon. Nah, I'll just avoid large bodies of water.
Old 02-24-2003, 07:22 AM
