-   -   Replacing the CAT with a muffler? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/995995-replacing-cat-muffler.html)
PeterCarrera84 05-08-2018 01:15 PM
Has any one done this in a non car inspection State?
Some one wrote me , but cant remember which type of muffler it was. I would like it to sound more like a Fabspeed w/o the expense (: :D
The car in question is an 89 S2 stock. with 97k
Any ideas ?
I have Borla cat back on my now for sale 08 Jetta(GLI clone) it does sound
very KOOL !! :cool:
v2rocket_aka944 05-08-2018 03:39 PM
you could do it, but it'll STINK without a cat.
PeterCarrera84 05-08-2018 04:33 PM
OK why did it not STINK when I did it to my old 84 911?
PeterCarrera84 05-08-2018 04:35 PM
so what would you recommend ? what really works ? a cat back ? which one if so?
9FF 05-08-2018 04:42 PM
Most Euro spec 944’s weren’t fitted with a cat and had a small intermediate muffler in its place according to pet.
v2rocket_aka944 05-08-2018 04:58 PM
maybe your nose isn't as sensitive...
i had a dead cat for some time and it REEKED...smelled like it was running rich all the time, but slightly different smell...CO poisoning for days.
it was a happy day to put a fresh cat back on.
RedCarGuy 05-09-2018 08:24 AM
If you've done it on other cars why are you asking again? exhaust options for 944/T/S/S2 is something that has been discussed ad nauseam on this forum and others. Do a bit of research and you'll find an endless supply of opinions and feedback.
PeterCarrera84 05-09-2018 11:03 AM
Thanks , but each car is a little dif. 3.2 oil kooled and 3.0 H2o kooled thats why I was trying to educate my self. not to make a mistake. Will do further research
Just purchased the S2 2 months . Thanks
924 05-11-2018 10:56 AM
Installed this cat last year with a borla, works great. The cat is a 3" for higher flow, just need reducers to go up a size and then back down. Same one that lindsey racing sells for a fraction of the cost.
https://www.amazon.com/AP-Exhaust-602207-Catalytic-Converter/dp/B000EPZEJI
http://i34.photobucket.com/albums/d127/jayzzzz4/1_2.jpg
http://i34.photobucket.com/albums/d127/jayzzzz4/4_1.jpg
PeterCarrera84 05-16-2018 12:17 PM
Factory cat equipped (same as factory decat) - 196.5 BHP @ 6500rpm & 184.2 ft-lbs of torque
Cat delete bypass tube - 197.7 BHP @ 6500rpm & 180.1 ft-lbs of torque
Cat delete custom resonator - 199.9 BHP @ 5500rpm & 199.2 ft-lbs of torque
The interesting thing is the differences in performance.
Cat delete bypass tube - +1.7bhp -4 ft-lbs of torque (yes MINUS 4 ft-lbs of torque!)
Cat delete custom resonator - +3.9bhp +15ft-lbs of torque
I found this on a previous post on 944 site. which had an explanation why this occurs.
In synopsis look at the results, has any one made a hook up like this replaced the CAT with a resonator? Like to hear what to have to say ,
thanks again
mikepellegrini 05-16-2018 07:32 PM
I punched the cats in both my cars and it never affected passing emissions.
What it did do was make the sound deeper and throatier - which I like.
There is no effect to the smell.
v2rocket_aka944 05-16-2018 10:40 PM
Surprising, having a dead cat made my car undriveable for more than a few minutes at a time. Smell sticks to your clothes.
So much better with a brand new cat now.
As to those dyno numbers, guessing that's a 968 or 951 numbers?
PeterCarrera84 05-17-2018 01:39 PM
S2 as far as I know from the post which I took it from, They were discussing S2 motors.
blackburb 05-17-2018 06:47 PM
Maybe it was literally a dead cat:D
J1NX3D 05-19-2018 09:02 PM
This is my stock front muffler. Ptno is 944 111 985 00 for an 8v like mine, 944 111 985 02 for the S2.
http://forums.pelicanparts.com/uploa...1526788937.jpg
PeterCarrera84 05-20-2018 06:44 AM
Thanks all the way from New Zealand, so you replaced the CAT with that stock muffler? How does it sound ?
PeterCarrera84 05-20-2018 06:58 AM
So this front muffler fits in the same space that the CAT was in ? Looks like a perfect replacement. Wonder how it sounds??
9FF 05-20-2018 07:17 AM
That’s the stock factory muffler fitted on some row cars that I mentioned a dozen posts ago. Yes it fits exactly in place of the cat but really doesn’t change the sound to any extent.
drkshdw 05-20-2018 07:20 AM
Originally Posted by PeterCarrera84 (Post 10043552)
...so you replaced the CAT with that stock muffler?
NZ would be a ROW car which did not have a catalytic converter from the factory. It has a pre muffler which is what he is showing you and giving you part numbers for.
PeterCarrera84 05-20-2018 07:49 AM
of course , thank you
PeterCarrera84 05-20-2018 08:22 AM
https://www.amazon.com/dp/B00CE2L7WC/ref=cm_sw_r_cp_api_mbiQAbQ1Y9Z9B
what about replacing the CAT with a resonator like this one ? It was suggested by a 944 member
E bay has it for less $
PeterCarrera84 05-20-2018 11:31 AM
I think if we replace the CAT, the engine will breath better, and probably will nor ran as warm.
The CATS tend to get pretty HOT, I could feel it with my old 84 911.
So the replacement muffler is not such a bad idea, or a resonator if one wants some grrrrr sound !! I like some sound it just feels faster (:
