Starting problem
After months of rebuilding the steering rack and pump and waiting on a new compressor I just finished installing the pump compressor and rack but I tried starting it up and the belts turn for less than a second but then stops and nothing happens
It's not the battery because the inside lights are fine and I recently replaced the battery
Maybe one of the belts is too tight?
Old 10-01-2019, 02:32 PM
What is the battery voltage? It could need a charge after sitting for a while. You could also get it load tested.
Old 10-01-2019, 03:32 PM
I dont have the equipment for that but I'll try jumping it
Old 10-01-2019, 04:10 PM
