84 944 fuse/relay block
I am looking for someone that has a 84 944 with a relay/fuse panel correctly connected that can help me identify on the back where a single wire bk/rd 1.0 mm factory female spade connector should be connected. The reason being that I took my car to a dealer to have a problem repaired and got it back with the original problem plus a few more. I have been slowly going through prints and forums and have been able to trace where a bk/ye wire hanging loose next to the bk/rd wire went to G-3 power window coil. I am convinced the bk/rd wire goes to G something (switched) or H (unswitched). G & H are both single male fast-on tabs an the back of the panel.
Any help is appreciated
thanks
