Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
New 928 Owner: Wheel Offset Question
Hi all -- longtime Pelicans might recognize my screenname: I used to post here all the time when I had my 944 and 951. Anyhow, I recently bought a 1983 928S to keep my 2007 987 Cayman S company in the garage. I'm in the process of getting it sorted out -- it's cosmetically a very nice car, but has a small handful of mechanical needs.
One of my first priorities is sorting out the wheels on the car. Eventually, I want to find a set of original-equipment flat dishes ("manhole covers") for the car. It currently has 986 Boxster wheels... which appear to have the wrong offset (the center caps won't fit onto the front wheels). In the meantime, I was thinking that spacers on the front would at least be a temporary solution to the wheel offset situation. I know that spacers aren't a perfect solution, but I figured it's better than driving around on wheels with the wrong offset!
I want to make sure that my info is correct here.
Original equipment: 16x7" ET65
I believe the wheels on there (correct me if I'm wrong) are:
Part# 986.362.124.00 17x7" ET55
If so, then 10mm spacers would bring the wheels to the correct offset, yes? I'm a bit hesitant, as the front wheels pretty much fill out the wheel well as it is. Advice welcome.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 02-02-2021, 06:40 AM
Writer/Teacher
CJFusco's Avatar
I'm hearing from some other online sources that the wheels I have on there are already the equivalent of having 10mm spacers on the car, and to bring it to the correct offset, I'd have to space the wheels IN (which is obviously impossible). Is this correct?
Old 02-02-2021, 08:10 AM
Beautiful shark.
Here's a video that does a nice job of explaining 'negative offset' and how to solve it.
https://youtu.be/bRcfNjodLA4
PCA National HPDE Instructor
2008 Boxster S Limited Edition #005
2008 Cayman S Sport - Signal Green
1989 928 S4 5spd
Old 02-03-2021, 09:59 AM
That is correct. you would need a negative spacer to get the wheels where they should be. run them like they are until you have the opportunity to pick up a set of manhole covers. For reference the fronts are all the same (16x7et65), but in 87 with the introduction of the S4 rear manhole covers picked up an additional 1" on the outboard side, aso are 16x8et52.3. You can mount the S4 rear wheels on an early car with no issue. the challenge with the 8" rear is the correct tire size of 245/45-16 is getting pretty limited.
Old 02-04-2021, 01:10 PM
