porsher
aston@ultrasw.c's Avatar
Suspension settings for the track
Anyone like to share their starting point for a track prepped S4?
Cheers
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 02-10-2021, 06:07 AM
GUMBALL's Avatar
Ft toe - 3/16"" out total
Front camber - 1.5 degree negative
Front caster - same
Rear toe - 1/16" in total
Rear camber - 1 degree negative
That should be a good starting point. Adjust camber by tire temp readings, or wear readings.
Front toe out gives better corner entry.
Old 02-13-2021, 11:22 AM
porsher
great, thanks
79 928 Race Car
Old 02-13-2021, 01:47 PM
there are so many variables but with my car which weighed 2600 lbs, 800 springs front, 350 rear
i used the following:
alignment -2.5 f camber -1.5 rear
1/8 toe in front 1/16 to in rear
i also had adjusted the bump steer with custom toe rod ends. You might find info here plus I have lots of stored pics Mark Anderson - Stroked 1988 928 S4
Old 02-19-2021, 10:35 AM
