hatch release button
does anyone know how to remove the switch/button from the little floor panel?
all help greatly appreciatedhttp://forums.pelicanparts.com/uploa...1632968737.JPG |
Going back on memory, I believe it unscrews; pull up on the knob, and hold it in that position. I believe there is a hole drilled in the side of the switch post, in which you can insert a steel pin or small screwdriver. Then you can counterhold the switch post while unthreading the large round knob. After that is removed, I think the switch bezel then gets unscrewed and the switch will fall out the bottom.
100% correct Opelotus!! Great discription!
yes, Opelotus, perfect instructions. Thankyou.
| All times are GMT -8. The time now is 10:53 AM. |
