hatch release button
does anyone know how to remove the switch/button from the little floor panel?
all help greatly appreciated |
Kyle C
Going back on memory, I believe it unscrews; pull up on the knob, and hold it in that position. I believe there is a hole drilled in the side of the switch post, in which you can insert a steel pin or small screwdriver. Then you can counterhold the switch post while unthreading the large round knob. After that is removed, I think the switch bezel then gets unscrewed and the switch will fall out the bottom.
1974 911 1978 928 5spd hillclimb special 1984 928S 5spd, 1986.5 928S auto 1983 944, 1984 944 track car 1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S |
100% correct Opelotus!! Great discription!
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
yes, Opelotus, perfect instructions. Thankyou.
