Flywheel lock tool
Hi
Porsche 1986 s2 AUTO
Do i put flywheel locking tool where starter motor goes .Or is there another place like on the manual cars.Thanks
Old 03-06-2022, 05:21 AM
Kyle C
I believe all the automatic cars have a small blanking plate where the clutch slave cylinder would normally mount up on the 5spd cars. Remove the blanking plate (two 13mm bolts?) and install the flywheel lock in its place.
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 03-07-2022, 05:51 AM
That's correct. The automatics have a block off plate in place of the clutch slave cylinder. I don't recommend securing the flywheel lock with the bolts that hold the block off plate in place. The block off plate bolts are too short for good thread engagement and will strip out of the housing threads when used with the flywheel lock.
Match up the bolt threads and get longer bolts. The holes go all the way through and have plenty of room behind them, so you don't have to worry about getting exactly the right length.
Old 03-09-2022, 04:21 AM
stepson's Avatar
Good call on that, Shifted!
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 03-09-2022, 06:40 AM
