I have a RHD 928S 1982
It has had quite a rebuild but the electrician did not finish his part, I have a number of wires dangling that I cannot identify, nearly everything works but I cannot find out why these are not connected, photos are from the centre of the car in the region of the rear of the stereo Any help would be appreciated Thanks Paul
Second Image of wiring
This is the other photo
original sound system still installed?
84 928 S - SOLD 2012 Cayenne S |
Original stereo is no longer there, there were wires under the seat that used to goto an amp
i can't really help you identifying those wires but these cars had a lot of option choices when new - mobile phone, cd changer, alarm...stuff like that - so they could be from one of those - i know i pulled a lot of wires from the console to the missing amplifier and fader knob on mine
Wiring ID
It a 82 model so not as many options, I was more concerned with the first phot with has large plugs and was no part of the sound system
You said "nearly everything works?" So what doesn't' work? Might give you a clue on where to look.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
The central locking does not work and I cannot find the button for the central locking either, what are the wire colours for this?
You need a schematic diagram to trace the wires. I think you can find one on line. Just do a search "Porsche 928 wiring", I found quite a few.
the wiring diagrams for these cars is pretty useless as far as i'm concerned - try following the wires to their other end - there is a central lock controller box back there somewhere
The German schematics are a little different but once you understand their way of showing things you can follow it.
