Twinreds's Avatar
High output alternator
Hi there guys:
I am looking to see if anyone has a high output alternator that can part ways with. I think I need to replace mine on my 1986.5 928.
Thanks!
Old 03-28-2022, 01:01 PM
Administrator
Matt at Pelican Parts's Avatar
it looks like the standard replacement is the Bosch AL-170-X.
If you're looking for something higher, then assuming that the 170 = 170amps, you might possibly be able to find something like a AL190X or AL200X (if such models exist).
-Matt
Old 03-29-2022, 11:48 AM
-Matt
Matt, can you confirm that? I thought the factory alternator was 100-115 Amp.
Old 03-29-2022, 01:58 PM
Stock output is 115 Amps.
I'm running a 3G style alternator on my 1987 (same mount as any 32v 928, including 1985). 200 amps. I'm extremely happy with it. There are higher outputs available, but you'll need to upgrade your wiring if you really need that kind of output. The main advantage to the 3G route is much better idle output performance.
I would attach supporting documents. Technical reference, step-by-step, and alternator RPM calculator. But, the Pelican forum doesn't support uploading them. So, here is where you can find them:
https://rennlist.com/forums/928-forum/1260910-how-to-mount-a-ford-3g-alternator-in-a-32v-1985-or-later-928-a.html
Or, send me your email address and I'll email them to you.
Old 03-29-2022, 05:06 PM
Twinreds's Avatar
Matt, do you have access to the spec sheet to verify if the 170 actually means the amp rating?
Thank you
Old 04-04-2022, 05:00 AM
The Bosch AL170X is a remanufactured 115 Amp alternator. It is NOT 170 amps.
Old 04-04-2022, 05:20 AM
Twinreds's Avatar
Thank you. The search continues...
Old 04-04-2022, 06:56 AM
There was no OEM high output alternator for the 928.
What about the link I posted above about using a 3G alternator?
Old 04-04-2022, 07:03 AM
Network Native
Danglerb's Avatar
3G stands for third generation design, and would be my choice for an alternator upgrade. If you have done something to draw a LOT more power, then maybe Greg Brown's reworked one.
Old 04-04-2022, 09:05 AM
Greg Brown uses a standard Bosch alternator stripped and put into an aluminum case that a local CNC shop makes so it will mount to the stock 928 mounting holes. That alternator suffers from the same low idle output as all Bosch alternators of that ilk. I forget the specific numbers off hand, but you're talking about under 70 amps for sure, but I think it's in the 30 amp range. You'll pay north of $1,000 for that alternator that has poor idle performance but fairly high output at higher RPM's. However, he doesn't offer an output curve with the four figure purchase, so there's no telling exactly what you're getting.
Or, go with the Ford 3G large case alternator that has very good idle output (90+ amps for the basic versions)and will cost around $200 for a brand new one with all of the fixings for ~130 to 150 maximum output. Or, go for a 200+ amp version (~110 amps at idle) with an output curve for ~$400 that will outperform the Bosch alternator by a mile. Plus, it's easy to swap in different pulleys to match your particular idle RPM and needs.
Old 04-04-2022, 09:18 AM
Twinreds's Avatar
I will look at your link attachment to see if it can appease my installation anxiety. I am not mechanically inclined, so was trying to get the most plug and play possible.
Old 04-04-2022, 11:08 AM
Gotcha. Where are you located? I'm hosting a 928 wrenching meet in May in the DC area if that's anywhere near you.
Old 04-04-2022, 11:11 AM
Twinreds's Avatar
Michigan. Too bad that is too far...
Old 04-04-2022, 11:53 AM
That would definitely not be worth it
At one point, 928 Motorsports had a high output alternator and Pelican resells a lot of their stuff. It was about $1k, and was basically just a Mechman 6G small case alternator with a custom case to fit the 928. Supposedly, the 6G small case alternators don't handle high RPMs as well as the large case alternators, but I don't have first hand experience with that.
They might still have that available, if you're looking for true plug and play.
Let us know which route you end up going. Feel free to drop me a line if I can help.
Old 04-04-2022, 12:22 PM
Administrator
Thank you for the clarification!
At one point, 928 Motorsports had a high output alternator and Pelican resells a lot of their stuff. It was about $1k, and was basically just a Mechman 6G small case alternator with a custom case to fit the 928...
It looks like we still carry 928 Motorsports products, but i combed through and found no mention of an alternator in our catalog nor on their website.
Feel free to drop us a message and we can try to reach out to them or try to find a vendor who might have a solution for you!
-Matt
Old 04-05-2022, 08:37 AM
Twinreds's Avatar
Thank you all. I am getting some advise from Dave K to see if I really need it, and if I do, he might have a solution. I will keep updating.
Old 04-28-2022, 06:47 AM
honerboys's Avatar
i also thought i needed a new alternator last year - battery would die if i didn't start it every week - needle would bounce around at speed - i replaced the voltage regulator - once with a cheap one (around $30) i found online somewhere - didn't help - then i got the better one (around $70) - it seems to have fixed my problem - this is the first winter i haven't had to put a charger on it in many years - and my battery is old - might that be your problem? - seems like you are not sure you actually need a new alternator
84 928 S - SOLD
2012 Cayenne S
Old 04-28-2022, 07:29 AM
Twinreds's Avatar
I actually do not need to even charge the battery after the winter, I do take it out and recondition it with the trickle charger, but the battery has actually survived the winters. I just don't see the charging needle high enough when the engine is running.
Old 05-06-2022, 01:13 PM
I would not rely on the factory voltage gauge to give definitive numbers. use a DVM and measure at the jump post and also confirm at the battery. if these voltages are good you should be fine, then use the dash gauge to monitor trends. if it reads lower than typical, reconfirm with a good meter.
Old 05-12-2022, 10:04 AM
In my opinion, you don't really need a true high output alternator if you're only running stock electrics. That doesn't preclude the possibility of the current alternator failing and being in need of replacement.
With respect to the voltage gauge in the dash, it is adjustable. When you pull the pod and gauge assembly out, there is a small dial on the side of the volt meter that can be adjusted so that the gauge matches the true volts. I did this on mine, using a reference source and multi-meter to confirm the voltage, and it is now spot on. I also have a TPMS receiver plugged into the cigarette lighter that displays voltage, and it matches the dash gauge.
I don't know for sure if this is true for all years, but it's true for at least '87+. I would assume that it's true for all years, though.
Old 05-13-2022, 09:02 AM
