Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Best Way to Fine Tune A/F Mixture?
So,
After doing a bunch of maintenance on my 1978 928 I have reinstalled the fuel distributor and set to an initial baseline mix which gets the vehicle to start. That initial baseline was from 928classics, and a PDF they have available. I'll edit this later but his site isn't coming up right now. Anyway, as I don't have access to any sophisticated exhaust gas analyzer, and assume most here don't either, how do you try and refine your mixture, particularly on the K-Jetronic system (not KE) Thanks for any tips!
cRaIg CaRr 2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer. |
CIS Air-Fuel Adjustment
Never turn the air/fuel adjustment more than 1/4 turn. Too rich, the engine will oscillate up and down at idle. From that point turn to lean, and when the RPM decreases it is too lean. Just bump it up a bit more rich and the mixture should be acceptable.
Talk Less, Say More
Thanks Rich!
That's what I ended up doing. I actually got a lot of information off a YouTube Mercedes video, and then another person with an older 911 that also had K-Jetronic. The oscillation is a giveaway now that I know about it, as are squealing injectors when you've gone way too far..
