harborman's Avatar
windshield washer
I am getting a good spray on the drivers side but nothing on the passenger side. Maybe one of those plastic tubes clogged. It looks like the fluid first goes to the passenger side.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 06-12-2023, 03:53 PM
honerboys's Avatar
i believe you are correct...pass side first - on mine it always seems to be those check valves that are clogged
84 928 S - SOLD
2012 Cayenne S
Old 06-12-2023, 05:42 PM
harborman's Avatar
Where are they located?
1986 928S
32 valve engine
Old 06-13-2023, 04:47 AM
stepson's Avatar
On mine, it is always the nozzles. I use a fine needle to re-open the nozzle.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 06-13-2023, 06:50 AM
harborman's Avatar
Ok, thanks. I tried that but I need to find a very thin needle.
1986 928S
32 valve engine
Old 06-13-2023, 07:12 AM
honerboys's Avatar
the check valves are right by the nozzles - up in the hole in the hood - very tight in there - if you are getting spray on drivers side then it's getting as far as the pass side - i believe there is a Y right near pass nozzle - so many lines up in the hood since the intensive washer also hooks in there somewhere
84 928 S - SOLD
2012 Cayenne S
Old 06-13-2023, 03:29 PM
harborman's Avatar
Yes, drivers side has good flow but nothing on the passenger side. I cleaned the nozzle but no luck. At first there was a very slight flow out of the passenger side, but now not a drop.
1986 928S
32 valve engine
Old 06-14-2023, 04:24 AM
honerboys's Avatar
sounds exactly like what i had - was those check valves
84 928 S - SOLD
2012 Cayenne S
Old 06-14-2023, 12:07 PM
stepson's Avatar
The Porsche engineers designed these with a failsafe. IIRC, I believe there are two complete systems for the water to get to either nozzle. If you remove one of the systems, you can replumb the system with a single hose and you will have plenty of extra valves and much less hose in your hood and water from both your nozzles.
Old 06-14-2023, 01:14 PM
harborman's Avatar
I think they hired a plumber from Hell to design that system.
1986 928S
32 valve engine
Old 06-15-2023, 04:05 AM
stepson's Avatar
I know they did. I took all the hose out of my hood on the Stepson (84 Euro) and used a singular water feed. Obviously, it wasn't hard because I got it done.
Old 06-15-2023, 12:38 PM
honerboys's Avatar
stepson - did that eliminate the intensive washer system? - i know no one uses it - not even sure if the fluid for it is still available
84 928 S - SOLD
2012 Cayenne S
Old 06-16-2023, 06:20 AM
