windshield washer
I am getting a good spray on the drivers side but nothing on the passenger side. Maybe one of those plastic tubes clogged. It looks like the fluid first goes to the passenger side.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
i believe you are correct...pass side first - on mine it always seems to be those check valves that are clogged
84 928 S - SOLD 2012 Cayenne S |
Where are they located?
On mine, it is always the nozzles. I use a fine needle to re-open the nozzle.
John Curry (Drift King) 928OC member Grand Prix White 1994 GTS AT (The GTS) Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz) |
Ok, thanks. I tried that but I need to find a very thin needle.
the check valves are right by the nozzles - up in the hole in the hood - very tight in there - if you are getting spray on drivers side then it's getting as far as the pass side - i believe there is a Y right near pass nozzle - so many lines up in the hood since the intensive washer also hooks in there somewhere
sounds exactly like what i had - was those check valves
The Porsche engineers designed these with a failsafe. IIRC, I believe there are two complete systems for the water to get to either nozzle. If you remove one of the systems, you can replumb the system with a single hose and you will have plenty of extra valves and much less hose in your hood and water from both your nozzles.
I think they hired a plumber from Hell to design that system.
I know they did. I took all the hose out of my hood on the Stepson (84 Euro) and used a singular water feed. Obviously, it wasn't hard because I got it done.
stepson - did that eliminate the intensive washer system? - i know no one uses it - not even sure if the fluid for it is still available
