MPDano's Avatar
Replaced my CIS Injectors today
I thought I would share my project today. I replaced my tired 29 year old injectors with the Mercedes ones recommended by so many out there. I also bought a new set of seals, eventhough the ones I had were less than a year old. I didn't want to chance it, plus they are inexpensive too. I ended up cracking one of my Collars, but luckily RJM65 lives a couple miles from me and also drives a CIS 928 and he just happened to have a few good ones from his MB Injector changout last week.
I used Silicone on the Seals and Anti-Seize on the Collar and Injector Threads
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 01-24-2010, 06:41 PM
MPDano's Avatar
Old 01-24-2010, 06:42 PM
MPDano's Avatar
Cracked Collar
Old 01-24-2010, 06:43 PM
MPDano's Avatar
Here's a quick video I shot too.
Old 01-25-2010, 05:48 AM
Heavy Metal Relocator
rhjames's Avatar
very nice, Leo.
did you rework the steel lines as well?
--R
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 01-25-2010, 04:24 PM
MPDano's Avatar
Originally Posted by rhjames View Post
very nice, Leo.
--R
I sure did Russ! I used a very expensive Harbor Freight Wire Brush to clean them off
Old 01-25-2010, 05:04 PM
Fabio421's Avatar
Why are you using those injectors? Are the original style injectors not available? It seems that the spray tip will be severely shrouded with this shorter injector.
1984 928's w/ 5 speed Smoked Quartz Metalic
1982 928's Turbo w/ 5 Speed Platinum Metalic
1978 Euro Widebody w/ 5 speed Guards Red
Old 01-26-2010, 07:47 AM
MPDano's Avatar
A less expensive alternative and lot's of positive user experience. I used to have a slight miss and it's totally gone. $20 vs $35 per Injector was big decision maker for me. Originals are still available.
Old 01-26-2010, 08:32 AM
rhjames's Avatar
that wasn't quite what I was referring to....
reworking the line ends:
using emory cloth, make sure the line end (each end, each line) is smooth and not deformed.
using a small drill bit, carefully drill out (open) the holes on each end of the line. start with a bit size that is just larger than one that will fit in the hole, and gradually work towards a larger size. be extremely careful to not let the bit get jammed in the line, or punch thru the line itself.
why is this important? you are making sure that each hole in each line is equally the same size. it does make a difference. each cylinder will be making the same power as the rest--as far as the fuel system is concerned.
this makes a huge difference on mechanical pump diesels (ex: Caterpillar), which use the same constant injections fuel systems---the same as your CIS on your P-car. the type of fuel used is of no importance, gas or diesel, the principle is the same.
I have done this myself on my Euro and Dad's US spec, in addition to the 047 injectors with great success.
--R
Old 01-26-2010, 05:51 PM
rhjames's Avatar
Cost Fab.....
$20 bucks for the 047 , $80 + for the OEM 928 units .
I actually bought an entire set of 047's for $56 delivered.....
--R
Old 01-26-2010, 05:53 PM
hitman3
me 2 change them all the work nice
Old 01-27-2010, 10:44 AM
With the injector nozzle being much shorter than the original does this not affect the spray pattern??
How well do they work? Any loss in power? What about MPG any increase or decrease?
The old ones look pretty bad so anything would be better.
Like the idea but want some hard facts before I offer tham as an alternative.
Thanks for the info.
www.************
Old 05-18-2010, 05:47 AM
The only direct replacement that I have seen is the 0437502012
www.************
Old 05-18-2010, 05:57 AM
Nice job Leo.
Roger, I've always thought the stock injectors went too far into the intake to get an even distribution of the fuel vapor. My next set for the 928 and 931 will be the MB units.
Dennis
Old 05-18-2010, 07:02 AM
MPDano's Avatar
Originally Posted by DPW928 View Post
Nice job Leo.
A few of us CIS guys have been using them (Benz Injectors) now with zero issues to report. Glad this topic helped you in your decision.
Old 05-18-2010, 07:17 AM
Zero issues sounds good but any data to back it up?
The other direct alternative is a Benz injector as well so as long as we are not mixing them up.
The idea is great but I need some facts to back it up.
As no one seems to have any I may fit a set to one of my cars and do some testing so that I can offer them as an alternative with a level of confidence.
www.************
Old 05-18-2010, 07:49 AM
MPDano's Avatar
Hi Roger. No data just my experience and another local fellow OBer too. Also, a couple more CISers like us here on Pelican that I consider to be reliable sources of info. I think it would be great for a reputable Vendor like yourself to run some personal tests.
I chose them since they were less expensive and have a good reputation.
Old 05-18-2010, 08:03 AM
Petie3rd
Mrmerlin's Avatar
FWIW I have fitted these MB injectors to 5 928 CIS machines ,
every one has resulted in excellent running performance.
I know this is an old thread but for anyone searching around today,
these MB injectors work fine.
Old 03-05-2025, 05:39 PM
