New User
Instrument cluster
I am working on a 1989 928S, a few days ago my instrument cluster just stopped reading correctly and my tach and speedo stopped working. My digital milage no longer works. The other gauges function but do not read correctly. Fuel, oil pressure, temperature, voltage is the only thing reading correctly. Just looking to see if anyone else has had this issue.
Old 09-30-2025, 09:00 AM
stepson's Avatar
Check all your connections on the back of the instrument pod and check the fuses. There are 3. Fuses 5, 10, and 24 must all be functional
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 09-30-2025, 11:03 AM
Banned
Sounds like a possible issue with the instrument cluster ground or a failing power supply to the cluster. Check ground G5 behind the dash and inspect the cluster connector for corrosion or loose pins. Also worth checking fuses and the ignition switch, as a failing switch can cause weird gauge behavior.
Old 10-08-2025, 04:49 PM
I've had very good luck with Mark at E tech for repair on the 89-95 clusters
tech@espeedo.com
Old 10-27-2025, 11:12 AM
