-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   1979 928 heater control vacuum line problem (http://forums.pelicanparts.com/porsche-928-technical-forum/216551-1979-928-heater-control-vacuum-line-problem.html)
danmaitzen 04-15-2005 02:25 PM
I am in the process of finishing a totally stock silver 1979 928.
Some of the vacuum lines on the back of the manual heater control slipped off when I removed the center console. I tried to re attach via trial and error, but that was impossible.
I need help or a schematic to re-attach the lines. I have attached a diagram of what I am working with. Any help is greatly appreciated!
http://forums.pelicanparts.com/uploa...1113600181.jpg
If the image does not load you can download it from here:
1979_928_manual_heater_control back
make sure you view the picture at full size so you can read the text
Thanks Dan Maitzen
dan@menterprise.net
801-557-1040
928ram 04-15-2005 04:08 PM
This should clear things up....
928ram 04-15-2005 04:10 PM
Ooops..hang on..
928ram 04-15-2005 04:13 PM
Try this...http://forums.pelicanparts.com/uploa...1113606828.jpg
danmaitzen 04-16-2005 11:03 AM
Thanks 928ram. That's exactly what I needed.
Dan
