1981 928 Brake Problem..Please help
When I step on the brake pedal to stop, I have to push the pedal to the floor. The pedal has some pressure, but it's not consistant. I had the shop replace and bleed the brakes and the pads are good. Do you think it's the Master Cylinder, Vacuum Booster, or Vacuum actuator? Please any info would be helpful. Also if you know a website that explains the repair, that would be helpful.
Please help
Old 04-05-2006, 01:04 PM
unclenick's Avatar
Send a message via AIM to unclenick
Sounds like the master to me.
1984 RoW Carrera Cab
1986 944 Turbo-sold for new home
2005 Suzuki Hayabusa-sold for new home
1986 928s 32V-sold
1978 911 Targa-sold
1987 924S-sold
Old 04-05-2006, 06:37 PM
I agree that it sounds like the master.
If it were the booster, you'd get a good hard pedal fairly low to the floor that would be consistant. It's certainly worth checking the check valve on the booster, or if you have a mityvac or similar the booster itself.
Old 04-06-2006, 06:48 AM
