Reverse - 81 928 Automatic not working
How hard is it to repair this problem?
Does the transmission need to be removed?
Any special Porsche tools needed?
How many hours to remove? Repair?
Any idea on cost?
Old 09-17-2006, 03:08 PM
Can be adjusted, there is a nut on the right (passenger side).
If you adjust it with the wrench at 12 o' clock and move it to 5 minutes past one may be reverse gear could be back, if not try further, but only milimetres...
If this doesn't work or it gets worse overtime it looks like a tranny repair, or replacement...
Old 09-29-2006, 07:25 PM
We have found that on a lift and in reverse that we can stop the rear wheels from turning. I have been told that it could be a band is out.
Old 09-29-2006, 07:59 PM
