LinkBack | Thread Tools | Rate Thread |
Good observations on the fuel economy. I'm hoping I can still get the 20-22 on daily drive...that is darn near what my 5 jug S4 gets back and forth to work (I tap into the boost a lot though). This is the true bueaty of the turbo, there is nearly zero penalty when cruising, even at high RPMs and low loads. It sits quietly in the background until you drop your foot and call for it. Your docile, well mannered 928 then becomes a real blast of a ride. With the way my 4.5 and 4.7 builds have turned out and knowing this car has so much more potential....let's just say I have high expectations out of it.
Regarding weight...I have not actually weiughed all the bits up, but I'm sure total there is some weight added. However, this is nothing 0.2 psi won't take care of in a hurry. ![]() In the case of my dog's stainless rear end, it was a shattered leg between the knee and the hip. The biggest piece was just one inch long...the rest was shattered. He got an erector set plate and was back in business after 6 weeks!
Kuhn Performance Technologies, LLC Big Gun: 1988 928S4 Twin Turbo, 5-SPD/LSD 572 RWHP, 579 RW ft-lbs, 12 psig manifold pressure. Stock Internals, 93 octane. Little Gun: 1981 928 Competition Package Twin Turbo, 375 RWHP, 415 RW ft-lbs, 10psig manifold pressure. Nikasil Block, JE2618 Pistons, 93 octane. |
Heavy Metal Relocator
Yeah, the Indy motor isn't quite a "street" engine, at least the one I was thinking about. 16:1 CR isn't quite streetable, but they do make a 605 ci motor at 10:1 (750 HP--775 ftlbs torque). Then again, I think I'd just drop the CR on the 655 down to get it streetable.
I was just curious if Herr had thought about a total engine weight including his turbo setup..... Everybody had no problem putting a Chebbie in a 928 (ala Renegade kit), but I was toying with the idea of dumping an all aluminum big block Mopar in one. (What the heck, it costs the same as Phil Threshie's 6.4L 32V stroker, but makes a lot more power---I've not seen any dyno reports of his making more than 500hp.) Dimensionally, I believe it would fit. Then it's nothing more than fabbing up adapters for the clutch and torque tube inputs..... motor mounts are easily fab'd using aluminum motor plates on each end of the block, bolting them to angle pieces welded to the frame (same way we build a drag car). No EFI to mess with, no computers to limit what you're doing, just raw power. Fun discussion, these things are, but when you're looking at the cubic dollars to do it (which ever way you go), one has to look at all of the possibilities. Of course, there's always a HEMI in that mix as well. Mmmm......750 hp to start with, then add a turbo setup. That would be a deal. Speaking of weight reduction: Changing from the 16 inch tire/wheel combination I had, to my current 19 inch tire wheel combo, had a net weight reduction of over 45 pounds. Now there's weight we can all afford to lose, if we're trying to go just a little bit faster. regards---rhjames ![]()
Absence of Evidence, is not Evidence of Absence. Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma." |
By the way Herr,
you might fix that wiring issue on your right front. looks like the ABS wiring--- Such a nice setup to have a busted bunch of wires showing..... I didn't notice any mufflers (?), and what size are the pipes you're using? Keep it up--looking very nice. regards---rhjames
Yes, my doner car has some miles...but this was planned...wanted to make sure the car could handle the boost with high miles.
For now the exhaust is stock, minus the rear can. The downpipes are 2.25" diameter. Longer term, I might upgrade to a dual 2.75" or so. My goal was to not have to upgrade the full exhaust on this car to make good numbers. KISS concept. Once the brain gets back from Ott's I'll be able to turn the car over...JUST as the weather is shaping up! Nothing like good timing! Cheers. HK
Herr-Kuhn, do you have a website, how can you be contacted?
Cheers, T_MaX 89 S4, Auto-box, Silber/Blue, 320ish RW HP/TQ |
T-max you can email him at herr-kuhn@netzero.net . He is out of town right now he will be back nexted week.
how is it coming ,john?
Im interested in doing this to my euro 85 16v but will probably have to drop the cr(10.?) whats your cr and max boost
The 16V cars run well on 8:1 The 32V cars shoudl be able to run decent boost on the stock compression because of the superior design of the combustion chamber.
I'm starting the tune on the 32V twin turbo today.
Hi, anyone know where I can buy those black filter adapters. Those that go on top of the radiator. PM me please or text 973 930 6164
Thread Tools | |
Rate This Thread | |
