LinkBack | Thread Tools | Rate Thread |
Kuhn Performance Technologies 32V 928S4 Twin Turbo Nearly Complete
Greetings,
I've come here as a new member to share some of my work to other 928 enthusiasts out there. My project was to take a garden variety 928 S4 and add the best form of forced induction, namely turbocharging. To further this, the system had to be top notch in its method of approach, both from a technical and aesthetic standpoint. The 928S4 twin turbo system offers the following: 2 Garrett GT series liquid cooled ball bearing turbochargers 750+ HP capacity 2 Air to Air bar and plate front mount intercoolers 10"X4.5"X8" High energy pulse flow designed exhuast manifolds, ceramic coated Dual Bosch compressor bypass valves Split exit downpipes, seperating wastegate exhaust flow from turbine discharge, ceramic coated Dual air filtration and inlet snout system Proprietary MAF junction box JDS Porsche SUPER MAF Shark Tuner massaged EPROMS, fuel and ignition as required Run delay turbocharger water circulation system allowing water circulation through turbochargers after engine shut down. This, that and the other... This has been a very argued about project for the last 3 years. I promised to bring back a full blown (no pun intended) twin turbo system for the Porsche 928S4. Why? Beacuse the car is worth such a system and this is the way Porsche would have built it. I have been working with turbocharged Porsche 928s since 1990 and it has always been a dream to build the ultimate 5.0 liter 32V 928 street machine for me. I also grew really tired of hearing that a Centrifugal Supercharger was the "top dog" way to go for the 928 and that "turbos don't work on a 928" Some people claim this is an imaginary project, or won't work, won't outperform a supercharger, is too complex, etc. Not true as the below pictures show. I investigated the "rear mount" turbocharger system for the 928 well over two years ago. I could never draw myself to even remotely warm up to that setup because the turbocharger is designed to extract the raw heat energy from the exhaust pulse. Additionally, mounting the air cleaner(s) under the vehicle was simply unacceptable to me. That meant front mounting was the only option for me, as it is for any factory setup or top notch tuner working in this field. Furthermore, splitting the bank loading with twins is the natural layout progression for a turbocharged V8 and is Porsche and Audi's choice for nearly all of their new turbcharged vehicles. In fact, BWM has seen fit to equip the new 3 series with twin turbos. The value is in generating an extremely responsive system, one which can deliver an ultra-wide powerband, not just a peak, chest-pounding dyno number. The widest powerband per pound of boost was the ultimate goal. I expect this setup to run circles around most new high performance cars on just 5 psig. I attach some pictures of my project. In the next 3-4 weeks I will be putting the finishing touches on the system and running the car in. The first setup will run a low 8 psig, but I'm expecting some serious performance at even these low boost levels. After all we are chasing 5 full liters of displacement here with the latest in Garrett turbocharger design. ![]() To date, this project represents 1000+ hours of investigation, engineering, fabrication, installation, etc. My motto has always been to do it the best way possible. For those willing to write the check I can be willing to supply the systems. More information coming by February, 2007. ![]() ![]() ![]() ![]() [img] http://forums.pelicanparts.com/uploads9/IMG_2173+copy1167966275.jpg[/img] ![]() ![]() ![]() ![]() ![]()
Kuhn Performance Technologies, LLC Big Gun: 1988 928S4 Twin Turbo, 5-SPD/LSD 572 RWHP, 579 RW ft-lbs, 12 psig manifold pressure. Stock Internals, 93 octane. Little Gun: 1981 928 Competition Package Twin Turbo, 375 RWHP, 415 RW ft-lbs, 10psig manifold pressure. Nikasil Block, JE2618 Pistons, 93 octane. |
Looks real nice John. Even looks like most of it would work for an '86.5, just need a place for the throttle linkage.
Heidi... '86 928S #0223 {Isoch} Garnet Red Metallic/Burgundy (crispy) Helmut '86 928S #1396 {Droop} Guards Red/Slate Gray Beth.. '86 928S #2641 {Isoch} Garnet Red Metallic/Burgundy Stage III Supershark Nearing 500HP Zelda.. '86 928S #2698 {Droop} Meteor Metallic/Burgundy |
Ah, the old 86.5! Actually if I'm correct the heads are somewhat different as well. I'll probably be going back and putting a similar manifold and modern turbocharger set like this setup on my 4.5 liter. The K-26/6 setup works really well on the 4.5 liter, but a set of these Garretts would really blow the lid off of things. The new wheel technology is leaps and bounds above the old school turbos...especially the turbine geometry with much smaller, higher flowing wheels. I really must finish this 5.0 build soon...the suspense is nearly killing me. I've been fabricating since August, 2006...and the investigation into this project steps back at least 18 months before that.
Banned
The exhause manifolds on S4s have more bolts than the 86.5 motors do IIRC. I seem to recall Dave Roberts telling me that once when i was discussing their X-pipe systems with him.
That turbo install looks awesome Herr-Kuhn, i want a freakin' ride when it's ready! ![]() |
Heavy Metal Relocator
As I have said in my previous posts.....
Another product to consider. Much more to my liking on several points: Air intake under hood--not under car. Air intake in front of radiator--nice and cool, above the rocks and road kill. Twin hairdryers--quicker spoolup (possibly) using smaller units. Headers into turbos--every competition turbo-ed car out there uses some sort of tubular headers to feed the turbo's. Herr-Kuhn is dead-on about heat content. 26 years of building/operating bad-ass diesel truck motors taught me that......(1000+HP V-8 Cat// 45 lbs of boost, 1250+ hp KTTA Cummins// 62 lbs of boost). I would like to see the 16 V (K-Jet) set up, when you have a chance to offer...... One further thought: "Compound turbocharging" Think about it........better o-ring your heads guys! Regards to all---rhjames ![]()
Absence of Evidence, is not Evidence of Absence. Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma." |
not-banned
Good work John.
I cannot wait to see the results. Very cool intake, palcement of the air filters is perfect. I've seen other setups play around with that type of placement, very simple and effective. Are the two intakes going through the fender? Is there an IC down there somewhere? Looks like you are in the home stretch. |
928 OB-Wan
turbos suck, easier to put a twin screw on it and be done
hahahahaha.... jk nice to see you're in the home stretch, I'm waiting on a call from your bro on the dyno numbers from his car
78 928 Euro 5spd #34 88 928 S4 AT NachtGrun/GrauGrun 88 928 S4 5spd Guards Red/Black 12 Volvo C30 IceWhite/Black |
Wow John! Looking good!
Any chance you will have this car at SITM this year? |
Banned
Hey Murf, how's it going bro? Long time no see.
murf928 this car will be at sitm this year
The beast 1984 928s twin turbo 5speed LSD/ 508.6RWHP 495RW ft lbs 12.5 psig manifold pressure, MS2 and EDIS-8 nikasil block JE 2618 pistons (TripleT). 2001 AUDI A6 4.2 chip 320 hp. 2002 CHEV Tahoe 4wd. 1971 sonett race car GT4 National Champion now GTL class car sold. The words of a Ford GT man. ( Damit i need to get some turbos) |
Truly a work of art,
will be very interesting to see the results on the rolling road. (and how the rest of the drive line can keep up with that ![]() /Peter
Stinger Last edited by 928GT and EuroS; 01-05-2007 at 03:08 PM.. |
Architecture & Porsche's
Very cool John!
Rhjames: my 3.5" intake is not "under the car" just because the pipe is. It's a very roomy, cool, dry place that's at least 16-18" off the ground. ![]()
Porsche Club Racing National Scrutineer '89 Andial 951 '82 928R '74 911 RSR 3.6 |
Mark,
I know what you're saying, I just prefer under hood for all engine components. I just couldn't "see" where it (your intake) ends up from the pics I was looking at (in front of the battery box/gas tank area.....? I hate these damn reader glasses...) Not you're fault Porsche didn't make a cavernous engine compartment...... It's a good debate, these things we add on to each of our cars. My roots are in drag racing, so it's difficult for me to even own anything that goes around a corner like my 928, much less think about how to (easily) double the HP output. Still learning after all these years....... Let's see, "compound" turbocharging, then intercooled, then nitrous oxide, then stroked and overbored.......wonder just how much these little engines will take....? I did have a little fun with Corvette and a 7 series Beemer today......The Vette was giving the Beemer a good run, and then I sneaked (that's terrible English) up on 'em. What a surprise! Keep after guys. When I get done building a new motor, I'll get serious about shopping for some more HP. regards---rhjames
New dyno run coming for triple t
Yes it looks very nice. Dang Shane, thanks for sharing :P
Yikes, can't wait to see this at SITM!
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Thanks for the feedback guys. I've been out of town on business this week in Chicago and had an issue with the laptop.
Sharkaholic
Also Herr Kuhn... Das ist ja wirklich unglaublich!!!
1991 928 S4, slate grey / classic grey, slightly enhanced... www.hookedoncars.com |
Nice one, John!
John '86 Euro S2 16v SharkTuned LH & EZ-F www.jdsporsche.com USA agent for LH and MAF checking and repair is Louie Ott :- www.performance928.com |
Just a few more weeks and she will be on the road!
Thread Tools | |
Rate This Thread | |
