Network Native
Danglerb's Avatar
Rusty flywheel, last main part for project car.
I got the last "major" parts today that I know of to put an 83 Euro S AT motor into my US 83 5 spd, a pair of 85 exhaust manifolds and a slightly rusty US 85 5 spd flywheel. Shop I got it from had the flywheel surfaced when they bought a complete motor, but its been outside for about a year I think.
Should I have much concern over the surface rust?
I wiped it down with an oily rag and other than the rust it seems fine, given that I have no clue what fine might be.
US 83 zinc metallic 5 spd, aka the nice car.
Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD
Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years.
Old 08-13-2007, 09:48 PM
Freiherr
Red Baron's Avatar
What does the contact surface look like?
Abby Normal
Old 08-14-2007, 04:54 AM
Network Native
Danglerb's Avatar
I've seen a lot worse on brake rotors that were still on a car and being used (just parked a few months), so I don't know how to judge. Here are a couple of picts.
Old 08-15-2007, 11:16 AM
Freiherr
Red Baron's Avatar
Hmmmm, I thought the torque converter bolt up to the flywheel and none of that surface is actually meshing with anything?
Abby Normal
Old 08-15-2007, 01:15 PM
Network Native
Danglerb's Avatar
The Euro motor I found is from a AT car, so it has an AT flywheel now, but to put it in my 83 5 spd I needed to find a LH toothed 5 spd flywheel to replace it. I can't use my 83 flywheel because its for a L jetronic.
BTW this was all a surprise to me too. Fortunately the 84/86 Euro and 85/86 US bellhousings are all compatible.
On the AT the flywheel has the flexplate bolted to it, then the torque tube with the TC back at the tranny.
Old 08-15-2007, 06:21 PM
Hey! Nice Rack! "Celette"
rich's Avatar
That flywheel wasn't resurfaced. If it was you wouldn't see the imprint of the pressure plate contact area. That would be ground off. Bring it to the local clutch and brake shop and have it ground.
Early Alien Sightings
914-M28/11 5.0 Hybrid (The Alien Sharkster)
I think I smell your blood in the water
WCC 04 done by the kids
Who says Aliens only abduct people.
Old 08-17-2007, 06:28 PM
