Garage: Yes but no roof.
928S Auxilliary air pump - where can I get one?
The bearings of my Auxilliary air-pump are shot, leaving me with 2 questions:
1 - is it possible to replace the bearings without replacing the whole pump? 2 - If I need a new pump, any idea where I can get it? I've searched for it here, but can't find the pump. Part number would be great if anyone has it. Frustrating thing is I see it in page 13-17 of the workshop manual, called the "auxilliary air pump", but I can't find the part for sale anywhere. any ideas would be great. thanks, Pauwl '84 928S Schifferblaumettallic - doing 40k km/year with it :-) |
I think I found it: OEM-92811301700
It's listed as a SMOG PUMP, but when you search on Pelican Parts you can't find it. Going via the air filter then, you get to the parts diagram, from there you click on the pump itself, and the SMOG PUMP gets selected. So only question 2 remains then: can I replace the bearings without replacing the $900 pump? thanks. |
928 OB-Wan
air pump = smog pump
if you aren't required to have it in your region I'd ditch it, just sucks hp and doesn't do that much on the early cars as for replacement, I don't know anyone who's swapped the bearings themselves, but you could get a good used unit from 928International for WAY less than $900 www.928intl.com
78 928 Euro 5spd #34 88 928 S4 AT NachtGrun/GrauGrun 88 928 S4 5spd Guards Red/Black 12 Volvo C30 IceWhite/Black |
Old 928 Guy
..so you could just disconnect the drive belt with no ill effects? (I have my '81 registered as "historic" do I dont have to pass any emissions tests
1990 C2 Cabriolet Guards Red ![]() '81 928 Zinnmetallic Project Car (sold) )'87 944na Maraschino Red Metallic (sold) )
Network Native
What I have been told on other cars, which may or may not be correct or apply is that disconnecting the belt and leaving the pump on the car will allow it to freeze up so it won't work in the future.
Wow do I hate the Calif smog nazi's , looking under my Mustang the other day I noticed the guys that installed my catted X welded in a line for the air injection even though my new OBDII style cats don't use it, because in CALIF its illegal to remove ANY of the smog equipment even if it isn't used.
US 83 zinc metallic 5 spd, aka the nice car. Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years. |
Heavy Metal Relocator
you can't just disconnect the pump, cause the belt that drives it also drives the fan, and the adjustment is on the air pump for that belt.
if you can locate a Euro idler pulley (which goes in place of the air pump--it has a belt adjuster), that is the way to go if you are not going to go further and install electric fans. HOWEVER------- I am removing my air pump and it's assorted piping, filter housing and such...... I would sell it for a whole lot less than the $900 quoted above. Send me a PM if you're interested. thanks--rhj
Absence of Evidence, is not Evidence of Absence. Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma." |
and yes, I can ship to France easily---the wife works for a freight forwarder based in France, and ships oil field related materials there (and on to Algeria) every week.
let me know if I can help with your pump issues....
If the used one does not work for you I have a brand new one you can have for $250.
Roger@************
www.************ |
