79 928 firing sequence needed
I've looked all over... can someone tell me which cylinders fire in what order? I bought a 928 and am putting in new plugs wires but can't seem to find what the firing sequence is. Thanks!SmileWavy
firing order is:
1-3-7-2-6-5-4-8 cylinders are as follows when looking from front of engine to the rear: Passenger side: 1-2-3-4 Driver side: 5-6-7-8 I suggest that you remove only one plug cable at a time for replacement. If you have taken all of the plug cables (wires) off at the same time, you can take the #1 spark plug out, put your finger over the hole and bump the engine until the piston forces the air out (this brings the piston to top-dead-center). Then remove the distributor cap to see which plug cable (wire) the rotor is pointing to. This one will be cylinder #1. You can then follow the rotation of the rotor in sequence with the firing order to attach the remaining plug cables to the distributor cap. Hope this helps---- |
Thanks so much RHJames! You're a lifesaver! Tim
Glad I could help.:D
You will find this info in the Factory Workshop Manuals, volume 1 (Engine, technical data, engine) page 0.5----- if you don't have a set of FWM's, contact Jim Morehouse for the CD's. his email is jim928@ptd.net the entire set including PET (parts) program and the technical service bulletins is about $80. You can also find the FWM's on eBay (be careful to buy the entire 9 volume set, some are sold with fewer volumes), for about $400.00, sometimes higher..... regards----:) |
rhjames is that for American 928? im in Australia and we steer from the otherside of u guys.
Standing in front of the 928 looking in the hood.
4 8 3 7 2 6 1 5 |
I am new to the 928.... But i believe it is also stamped on the heads as well...at least it is on mine
Distributor Counter Rotation -
Hey Anderwjt, One other ignition problem you might have in Australia, I think that your distributor rotates in the opposite direction down under to counter balance the driver's seat being mounted on the right hand side of the car....;)
My wife and I spent a couple of vacations up around Mackay and the Great Barrier Reef. During our travels through Eungella I actually saw a platypus in the wild. Great place to visit with lots to see and do - Good Luck with your car - :) Michael |
| All times are GMT -8. The time now is 03:20 PM. |
