Tim 79 928 Owner
79 928 firing sequence needed
I've looked all over... can someone tell me which cylinders fire in what order? I bought a 928 and am putting in new plugs wires but can't seem to find what the firing sequence is. Thanks!
Old 10-10-2007, 05:41 PM
Heavy Metal Relocator
rhjames's Avatar
firing order is:
1-3-7-2-6-5-4-8
cylinders are as follows when looking from front of engine to the rear:
Passenger side: 1-2-3-4
Driver side: 5-6-7-8
I suggest that you remove only one plug cable at a time for replacement.
If you have taken all of the plug cables (wires) off at the same time, you can take the #1 spark plug out, put your finger over the hole and bump the engine until the piston forces the air out (this brings the piston to top-dead-center). Then remove the distributor cap to see which plug cable (wire) the rotor is pointing to. This one will be cylinder #1. You can then follow the rotation of the rotor in sequence with the firing order to attach the remaining plug cables to the distributor cap.
Hope this helps----
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 10-14-2007, 09:46 PM
Tim 79 928 Owner
Talking
Thanks so much RHJames! You're a lifesaver! Tim
Old 10-15-2007, 11:34 AM
rhjames's Avatar
Glad I could help.
You will find this info in the Factory Workshop Manuals, volume 1 (Engine, technical data, engine) page 0.5-----
if you don't have a set of FWM's, contact Jim Morehouse for the CD's.
his email is jim928@ptd.net
the entire set including PET (parts) program and the technical service bulletins is about $80.
You can also find the FWM's on eBay (be careful to buy the entire 9 volume set, some are sold with fewer volumes), for about $400.00, sometimes higher.....
regards----
Old 10-15-2007, 03:53 PM
Anderwjt's Avatar
rhjames is that for American 928? im in Australia and we steer from the otherside of u guys.
Old 03-19-2012, 09:23 PM
Network Native
Danglerb's Avatar
Standing in front of the 928 looking in the hood.
4 8
3 7
2 6
1 5
Old 03-19-2012, 10:28 PM
Kool
AirtekHVAC's Avatar
I am new to the 928.... But i believe it is also stamped on the heads as well...at least it is on mine
Old 03-20-2012, 08:35 AM
JK McDonald's Avatar
Distributor Counter Rotation -
Hey Anderwjt, One other ignition problem you might have in Australia, I think that your distributor rotates in the opposite direction down under to counter balance the driver's seat being mounted on the right hand side of the car....
My wife and I spent a couple of vacations up around Mackay and the Great Barrier Reef. During our travels through Eungella I actually saw a platypus in the wild. Great place to visit with lots to see and do -
Good Luck with your car -
Michael
1984 928S - "Miss Purdy"
1987 911SC - "Frau Helga"
1986 930 - "Well Hung"
1975 911 Targa "Blue"
Old 03-20-2012, 03:50 PM
