cam noise& Timing help
Hey last night my motor started making a noise that first sounded like a stuck lifter. I did trouble shooting this morning pulled my timing covers off and seen what seems to be the passenger side timing gear wobbling a little (had some front to back sway) what is the chance the front cam bearing going out?
Oh yeah.....its an 84 Us. Also I found my timing mark on the gears what do I align them up with on the left and the right engine side housing? Pics can be found where I posted the same question on rennlist http://forums.rennlist.com/rennforums/showthread.php?t=386358 Thanks for any help. Brian Felts |
Problem solved......as I began to take my baby apart I found the cam sprocket lose. Yeah it was a little less than finger tight. Torqued it down and the noise is gone without any failers or snapping the cam.
CHECK THESE BOLTS ON YOURS.....I know the timing belt was replaced before I purchased the car but the bolts were never touched!! It backed out on its own. Brian |
I wondered if it could be that simple, but too much potential trouble messing around there for me to venture an amateur opinion.
You just can't trust ANYTHING a previous owner or their mechanic has done to your car. |
amateur ? No I value your opinion plus nobody could be more amateur than me ;) when it come to Porsche You are truly right about not trusting the last owner.
Brian |
| All times are GMT -8. The time now is 06:45 AM. |
