-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Block stored 20 years with piston in, good/bad? (http://forums.pelicanparts.com/porsche-928-technical-forum/378930-block-stored-20-years-piston-good-bad.html)
Danglerb 11-23-2007 10:42 PM
Noticed this on ebay, a new 79 block stored 20 years with the pistons in the cylinders, is that good or bad? I'm guessing bad from the overall look.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=320186850413
911blex 11-24-2007 01:29 PM
I am think it might not be a bad deal since it is only a short block. IMO, it would be a different story if this was a fully assembled engine that had 20 year-old fluids in it.
Just my $.02
rhjames 11-26-2007 08:10 PM
not great-----
no crank, rods, or bearings.
m-a-y-be no rings either....?
$$$ for a 4.5L block and pistons is way too high.
(I've got one here at the house with a new set of Euro pistons that I'd be tempted to let go for the same price he's asking.......)
--Russ
rich 12-03-2007 09:08 PM
Excuse my ignorance. but I didn't see where the ad stated the engine is a 4.5 Aren't those 4.7 euro "S" pistons? I need to look at my manual on CD, but I thought 4.5 pistons looked different that 4.7 "S" style.
The block is fitted with later gold head studs.
Danglerb 12-03-2007 09:35 PM
78/79 were all 4.5L. Not much market for a 4.5, local guy has one fully rebuilt by a good local shop with an asking price of $900 last I looked. Kibort hasn't been able to sell the 4.7L motor he rebuilt either. Not that much looking turns up a running complete intake to exhaust motor for around $500, and if you want performance spend the money for a Euro or hybrid.
Without dancing around it too much, most OB owners are pretty cheap.
rhjames 12-05-2007 07:06 PM
that one that is advertised has Euro pistons in it.
but it's just a block and pistons---no rods or crank.
--Russ
Danglerb 12-05-2007 09:56 PM
Whats the difference between a Euro and US 4.5L piston?
The chart I have from I think 928gt.com shows 78/79 us and euro as 8.5:1, then US goes to 9.0 and Euro to 10.0, but doesn't say if its piston or heads.
Link to some pictures would be good.
rich 12-06-2007 06:40 AM
I looked at my manual on CD but it didn't picture the 4.5 piston shapes. Only the 4.7 US and euro.
I tried to ask the seller what the block # (M28/??) was but the auction ended. Unless the all 4.5 pistons were notched and flat topped like the 4.7 euro "S" pistons I think that was a euro "S" engine.
Still, the auction had a reserve and an opening bid of $ 850.00. It's likely the the seller was looking for a grand without a crank or any other stuff for a 4.5-4.7.... Now if it were a new euro 5.0.....
Danglerb 12-06-2007 09:46 AM
That auction was for a non S 4.5.
I think somebody built a 5.4 using 968 pistons and a standard crank.
rhjames 12-06-2007 01:14 PM
d---
difference in compression ratio's is in the piston---not the head.
if I remember correctly, US and Euro 4.5L use the same head.
Euro 4.7 is where it all changed.
like I've said before, I've got a brand new in box set of 4.5L Euro pistons w/rings (high compression) that would make a killer 4.5L for $500 if some one needed them......top that with a 4.5L short block that I' have, and $750 could get it all.
but then again....you just about can't give this stuff away.
how sad......
--Russ
rhjames 12-06-2007 01:44 PM
here's the difference you seek........
because of the camera flash, it is difficult to see the "dome" on the 'Euro' piston, but I can assure you it is significant.
4.5L US spec short block
notice the dished piston tops (before I wiped them with a rag). this is the same piston that the early 4.5L Euro engine uses at 8.5:1 CR.
http://forums.pelicanparts.com/uploa...1196976918.jpg
4.5L US spec short block, with 4.5L "Euro" piston (10:1 CR) inserted. Notice the dome on the Euro piston, and the dish on the US piston (after I wiped it with a rag).
http://forums.pelicanparts.com/uploa...1196977105.jpg
Now, a 4.5L Euro piston next to my 5.0L 32V piston that has been notched of 16V use.
http://forums.pelicanparts.com/uploa...1196977213.jpg
hope this shows you what you were searching for-----;)
--Russ
rhjames 12-06-2007 02:06 PM
I've tried to show the dome on these pistons, but the shine keeps hiding the difference in piston topography.
maybe on these pics you can see it.....
as far as I know, all 4.5L Euro's used this same piston on years 80-82
Rich---
the engine in question could not have used the Euro "S" piston (4.7L), because it does not fit (without overboring).....remember, this is advertized as a 4.5L block. With out piston #s, no one can say for sure, but my guess is this one just has the Euro 4.5L pistons.......
---Russ
http://forums.pelicanparts.com/uploa...1196978430.jpg
http://forums.pelicanparts.com/uploa...1196978474.jpg
Danglerb 12-06-2007 04:05 PM
Thanks Russ, I think I see the dome, at least enough that next time I have a piston in front of me I will know what to look for.
rhjames 12-06-2007 07:17 PM
yep, I went back and checked head numbers as well, just as I suspected. same head number for 4.5L US and Euro's, and 4.7L US. Euro "S" got the big valve heads only. Therefore, no changing heads for smaller combustion chambers to up the CR.
I was pretty sure all of that was correct, but had to do a refresher course....
it's all in the pistons----D.
--Russ
rhjames 12-06-2007 07:40 PM
problem with doing this stuff from memory is..... I have a bad memory.....
looking at the ad again, hopefully for the last time, Rich may very well be correct about it being a '80 plus 4.7L Euro block/pistons.
the pistons are flat topped, and since it's been a while from the last time a cracked open a M28/11, this may be the deal.
if you read the ad closer, you will see he didn't specify what year or size the block is----only that it was bought to replace a 77-79 engine.....that's what threw me off.
I withdraw any criticism towards Rich about his diagnosis----he may just be correct??
anyway, it's something to think about....
--Russ
Danglerb 12-06-2007 08:56 PM
The number on the block 928 101 905 01 matches up to a 78/79 remanufactured block.
MPDano 12-24-2007 06:35 AM
Whos this local guy with the engine?
Danglerb 12-24-2007 05:02 PM
Engine is in Costa Mesa, CA if that is local to you, PM me with a email address and I will pass it on to him. Your down in San Diego with the Euro 79? From what I have read on your car it isn't the engine that is bad is it, its the fuel system etc? This rebuilt engine is a long block, but no intake or fuel injection.
rich 12-24-2007 06:16 PM
OK, I agree the block # listed is a replacement block # for a 78-79 928.
But the pistons shown are not 4.5 US or euro. The pistons shown are 4.7 "S" flat tops. Is it possible the factory replacement for the 78-79 was up-rated to the euro "S" short block as they phased out the 4.5 displacement?
In any event, the 4.7 (even the "S" ) is not on the top of the desirable list. For that amount of money (no rods, crank, pump, pickup, oil pan,etc.) you could get a good 5.0 short block for a hybred.
I'd pay $350.00 shipped.
Danglerb 12-24-2007 08:03 PM
I think its about $500 to ship a block much distance. 928Intl has 5.0 Short blocks for about $1000, which seems fair enough to me. I've barely missed a couple complete engines for $500, but when the time comes that I "need" a short block, I'll just buy one from 928Intl if I haven't found one.
*** US 85/86 5.0L
**** zero interest in anything 4.5L
MPDano 12-25-2007 01:27 AM
Hi DanglerB, I am the one with a 1981 928 Euro.
Danglerb 12-25-2007 01:25 PM
Hi Danno, I just read your thread on Rlist again. Seems like you have something of a mix of various parts from different cars, best I think to fully investigate what you have and what is wrong with it before spending much.
The M28/10 ID on the block means its a non USA motor (but not an S either) for an automatic transmission car. It uses the same CIS (continuous injection system) as the US 78/79 models, with essentially the same power output, but higher gas consumption than later electronic injection models.
As others have said, the front fenders are not Euro, and one of the intake tubes is Euro S and the rest are not. Why these items were changed is an important question, and could change how best to proceed.
BAR (Bureau of Automotive Repair) keeps a record of every cars smog test history, I think, as the new owner you may be able to get a complete record, not just the pass or fail, but the complete test results which may give a mechanic a MUCH better idea of what has gone wrong.
100k miles is too low to suspect any material wear on the engine internals without some kind of "event" that broke something. Sitting with old gas tends to clog every segment of the CIS, and thats not a minor thing to fix.
Send me a PM (click on my name to the left of this message) with your email and I can pass it on to the owner of the motor, but as I said, its a long block without injection or intake, and those are the parts I think you need.
