Garage: Yes but no roof.
HELP: Removing front brakes
I'm replacing the brake pads & discs.
I can only get 1 of the 4 countersunk bolts off to remove the discs (2 bolts per wheel - on the faceplate of the disc after you've removed the wheel). I've tried WD40 to lubricate, but no joy. Any ideas? Will tapping it anywhere help? Will I have to drill them out?
'84 928S (Euro) Automatic Shiefferblaumetallic |
Network Native
I've stocked up on several penetrating oils, WD40, PB Blaster, Kroil, Liquid Wrench, and a few more still to go like the GM stuff.
Here are a couple threads. http://66.236.61.177/showthread.php?p=3490364 Whats on your shelf of goops and sprays? |
An impact screwdriver will get those out every time (the kind you hit with a hammer). Here's an example of one:
http://www.sears.com/shc/s/p_10153_12605_00947641000P |
Yep, what they said. Impact screwdriver. If you don't want to buy one. Take a screwdriver and hold it in a pair of chanel lock pliers. Hold some steady pressure in the counter clockwise direction and start tapping it with a hammer. The larger the hammer the better. You'll get it out.
1984 928's w/ 5 speed Smoked Quartz Metalic 1982 928's Turbo w/ 5 Speed Platinum Metalic 1978 Euro Widebody w/ 5 speed Guards Red |
You can also try some heat...that may help. The impact screwdriver is a must to really get them off though.
Kuhn Performance Technologies, LLC Big Gun: 1988 928S4 Twin Turbo, 5-SPD/LSD 572 RWHP, 579 RW ft-lbs, 12 psig manifold pressure. Stock Internals, 93 octane. Little Gun: 1981 928 Competition Package Twin Turbo, 375 RWHP, 415 RW ft-lbs, 10psig manifold pressure. Nikasil Block, JE2618 Pistons, 93 octane. |
Thanks all,
Heat applied with a heat gun, gave it a whack, and got them all off. appreciate the help. Will need an impact screwdriver for sure though now. Pauwl
Use some never sieze on them before you reinstallation. It will keep you from having this issue ever again. The bottom of the head needs to be lightly coated as well as the threads.
Network Native
Impact screwdriver is cheap, everybody should have one, and even better remember that they have it.
