Send a message via ICQ to Bill Kelly
Need help with 928 dash
Will a '89 dash interchange with a '87 ?
Old 12-30-2007, 02:17 PM
928 OB-Wan
Rixter's Avatar
yup, dash is same from 77-89
78 928 Euro 5spd #34
88 928 S4 AT NachtGrun/GrauGrun
88 928 S4 5spd Guards Red/Black
12 Volvo C30 IceWhite/Black
Old 12-30-2007, 03:22 PM
gbarron's Avatar
....um, didn't the 89- dash incorporate the digital display? I don't think they are interchangable...
Glenn
'89 928S4 32V - Linen Metallic
"Life only begins at the very end of your comfort zone"
Old 12-31-2007, 03:00 PM
928 OB-Wan
Rixter's Avatar
we're talking dash not instrument cluster or pod... the pod itself only has a couple variants, and early pods can be converted to later style
dash only has 2 styles, airbag and non airbag... and the airbag dash can be altered to use in a non airbag car
center console only has 2 true styles, 78-79 w/out temp sensor and 80-95 with temp sensor
Old 12-31-2007, 03:17 PM
gbarron's Avatar
Gotcha...
Glenn
Old 12-31-2007, 03:18 PM
Garage: Yes but no roof.
Can you then fit airbag versions to OB's and get them working, or is there too much plumbing to be done?
'84 928S (Euro) Automatic Shiefferblaumetallic
Old 01-01-2008, 08:13 AM
928 OB-Wan
Rixter's Avatar
not sure it would be worth the trouble, you'd need bags/controllers/harnesses/sensors etc etc
Old 01-01-2008, 10:58 AM
Network Native
Danglerb's Avatar
USA has a bunch of regulations related to the air bags, that might limit what can legally be done as well as what's practical to be done.
Airbags can also deploy under fairly minor conditions, and the amount of damage can total a 928. Start with the dash ripped apart and the need to replace the airbags, add to that I've heard the windshield often pops out on to the hood and fenders.
Strong feelings both ways on 89 vs 90.
Old 01-01-2008, 07:49 PM
How hard is it to replace the dash and what alls involved?
Old 01-02-2008, 10:45 AM
A Wrench
SeanR's Avatar
Don't forget the allen bolts (3) at the steering column hinge on the bottom. Be careful, they strip easy.
Old 01-03-2008, 06:27 AM
