Warm Up Regulator Replacement Alternative
I installed a WUR alternative about 2 weeks ago and things are great so far. I thought I would share my results. Ihave posted this info to other forums so I apologize if you have already read this somewhere else.
Product URL: http://www.unwiredtools.com/utcis.asp I am in no way affiliated with this company. The product offering supports 3 stages, each one costs a little more. 1. UTCIS-G Warm Up Cycle and Fixed Control Pressure 2. UTCIS-V Warm Up Cycle, Control Pressure Mapped to Manifold Pressure 3. UTCIS-PT Warm Up Cycle, Control Pressure Mapped to Manifold Pressure over 1 Bar ( for turbos ), Control Pressure Mapped to RPM Unless you are having WUR problems or have modified your motor and need more fuel I don't think it would be of much practical use. Essentially it replaces the Bosch warm up regulator on CIS cars with a programmable control pressure regulator. It mounts in the same location as the WUR with the addition of a ECU that I mounted on the left inner fender in front of the coil on my 928. I can program the control pressures during warm up cycle ( from 0c to 40c ) and also the control pressures after warm up with manifold pressure ( .4 to 1 bar ) via my laptop. Right now I am using the factory control pressure specs from the warm up regulator. But this product allows me to adjust for better WOT ( probably need a wide band sensor to really mess with this ). If I lived in a place where the climate varied dramatically I could adjust the warm cycle as needed. Monitoring the control pressure and manifold pressure is as easy as plugging in the serial cable into my laptop. This price is a little on the high side but compared to a new WUR it is cheaper. Before install ![]() UTCIS Installed in WUR Location ![]() UTCIS ECU ![]() My 928, wifes mini van, and my f150
1978 Porsche 928 5psd |
