Old 928 Guy
Checking Oil Pressure Sensor
Anyone know a relatively easy way to check the output of the oil pressure sensor? My oil pressure gauge pegs upon startup and stays there...I've rebuilt the instrument cluster so i know all the grounds, lines, etc are good...but i can't find any info in the shop manual about what readings to expect fromt the oil pressure sender. I figured I could go the main circuit board to check the values but don't know what readings to look for.
Thanks!
1990 C2 Cabriolet Guards Red ![]() '81 928 Zinnmetallic Project Car (sold) )'87 944na Maraschino Red Metallic (sold) )
I have the same issue. Pegs at the top of the scale and stays there. Always has, and instrument cluster R&R fixed many things, just not that. Where does the sensor plug in on the engine?
Ed 85 928 5 spd (guards red over tan) 07 Shelby GT500 6 spd (torch red over two tone black and red leather) |
Old 928 Guy
i had assumed it was the sensor on the top of the oil pan, but need to double check. i was also excited after i rebuilt the cluster because someone in the past had removed many of the trouble lights..now everything OK except coolant temp and oil pressure
The sensor is on the bottom of the engine between the oil pan and oil filter right behind the alternator. There are two wires that come off it. From what I've heard and experienced when you replace it the whole assembly usually comes out. Simply remove the sensor part and reassemble being carful to make sure the springs are in the right direction.
99 Boxster 5-speed 12 Acura TSX 6-speed |
Old 928 Guy
..but is there a way to check it?
I believe you can test it with a multimeter but I don't know what the range is suppose to be. I'm sure someone with more experience will chime in.
You might want to try cleaning it as it gets kind of mucky but because of location, cost of oil, and general pain in the neck I just chose to replace mine.
Network Native
Best way to check it is testing vs a known good mechanical gauge.
If it shows pegged hot at an idle, and your not running Amzoil, then I would suspect its not working. Check the wires, and measure the voltage to make sure its not something simple before replacing.
Old 928 Guy
thanks..it should be easy enough to check for shorts/opens. the gauge pegged from when i first bought the car, which wasn't a shocker with all the other electrical issues it had..but I'm slowly fixing all the other problems, so would be nice to know that i have oil pressure!
From the schematic i cant tell what's actualy going on inside the sender unit, and so the circuit geek inside me is bothered.
928-Electrics Guy
There are three connections...
The body (ground to the block) the low pressure switch and the pressure sensor. The last 2 are terminals.. If you swap the wires you will get a switch input to the dash input that expects a variable input (pressure gauge) and a variable input to the dash input that expects a switch to turn on the low pressure light. try swapping the connections - what do you get... The Blue/White wire should go to the G (sensor) terminal & the Blue/Black wire should go to the Wk (switch) terminal. Alan
1994 928 GTS Black/Black Manual |
Old 928 Guy
excellent..never thought the wires might be switched (shame on me because i have the schematics!)
