Brake help needed!
Hi and thanks!
I have repllaced my front rotors and pads for the first time and have run into an issue being that following the first pedal depression the brakes won't release.
When I installed the rotor and new pads everything went on smooth with minimal force. The new pads slipped in very easy.
I completed both fronts, hopped into the car and pumped the brake a couple and tried to move the car and in felt like the brakes were 'on'.
I took the wheel off to inspect, the rotor was super tight and wasn't spining. I wacked it with a rubber mallet a couple times and the rotor worked itself free again. I checked the fluid, even removed a mall amount.
Popped the whell back on and same issue; after the firt pedal depression it seems like the callipers wont let go of the rotor.
Any suggestions or guidance will be most appreciated!!
James
jmazillo@magbank.com
Old 04-10-2008, 06:54 AM
Old 928 Guy
surfdog4's Avatar
what year? My calipers had rusted from sitting when i bought the car and i needed to give them a good wire brushing and a little grease to get them moving freely
1990 C2 Cabriolet Guards Red
'81 928 Zinnmetallic Project Car (sold) )
'87 944na Maraschino Red Metallic (sold) )
Old 04-10-2008, 08:58 AM
Network Native
Danglerb's Avatar
Did you flush the brake fluid with new?
Old 04-10-2008, 11:14 AM
nosnow4pc's Avatar
Do both front calipers react the same or is this unique to one side?
99 Boxster 5-speed
12 Acura TSX 6-speed
Old 04-10-2008, 12:11 PM
