-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   1980 928 engine problem (http://forums.pelicanparts.com/porsche-928-technical-forum/405907-1980-928-engine-problem.html)
swooney 04-25-2008 11:28 AM
Hi
Im a bit clueless about engine faults but my 928 has developed a problem above 2000 rpm is looses power. Any thoughts from anyone?
Mark
Danglerb 04-25-2008 01:26 PM
When did it start doing this? Any work done to it around the same time?
We need a LOT more details, is it US or Euro?
What exactly happens?
Does it always happen?
swooney 04-25-2008 11:58 PM
The car has been in the garage for a few months. Starts and drives fine and was perfect before being laid up. Its a UK spec one.
Yes seems to happen all the time ie you pull away fine and increase speed as soon as it gets to around 2-2500 rpm the car pulls back like its being starved of fuel. Although its not coughing or juddering.
I thought at first it maybe the plug leads so ive ordered a new set but it fires up without a hitch.
Barbapapa 04-26-2008 03:59 AM
Sounds like CIS issues. You can try easy stuff like fuel filter, checking pressures and flow but it's possible that nothing will help until you rebuild the fuel distributor and WUR.
There are little filters under each of the 8 outlet fittings on the fuel distributor. It's easy to remove them with tweezers. That would be an easy thing to check without fully rebuiding the distributor.
ROG100 04-26-2008 07:11 AM
Could also be the fuel pump - remove the rear cover and make sure non of the hoses are kinked in any way. If the pump is noisy its probably toast. Common problem when the pump is attached to the cover.
