MPDano's Avatar
Removal of fuel Level sending unit in tank
Got another Fuel Tank question. I can't seem to be able to remove the sending unit. I tried to twist it in different directions and pull up, but no luck. Is there a secret handshake for this?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-26-2008, 06:45 AM
I assume you have removed the large retaining nut - looks like you have.
The sender is probably stuck in place and will require some gentle prying.
www.************
Old 05-26-2008, 09:07 AM
MPDano's Avatar
I can get it as far as an inch out, but it wont go any further. I thought maybe it was a weird shape inside so I turn it in several different positions but it wont come out.
Old 05-26-2008, 09:33 AM
Network Native
Danglerb's Avatar
Proceed with care, new tank $1k. I've heard people say its tricky, but I don't recall details.
Can you see anything with a mirror maybe from the bottom hole?
Old 05-26-2008, 09:48 AM
MPDano's Avatar
Mike, how did you clean your tank? Did you remove the sender unit?
Old 05-26-2008, 09:52 AM
Network Native
Danglerb's Avatar
Leo, pretty funny, while you typed that, I typed a new post asking how to clean the fuel tank.
Old 05-26-2008, 10:00 AM
MPDano's Avatar
Got it! Basically there is a cap of some sort inside and the sender unit sits inside of it. It was catching on the cap and in the time I was yanking on the sender, the cap came loose and the sender came out. The cap must be put on before they seal up the tank since the there is no way a normal human hand can fit inside that top hole. Unless the Germans had hands the size of a 3 year old. anyways, the sender looks fine as I can hear the float move up and down if I turn it over. I am wondering what is the purpose of this cap and what are the affects of not running it as I am forced to do.
Old 05-26-2008, 10:31 AM
The cap goes on top of the lower bowl where the intank pump sits.
It stops crud getting into that area.
To clean the tank I use a high pressure washer with the prssure turned down a little.
Depends how bad the Varnish like deposits are on the sides of the tank.
www.************
Old 05-26-2008, 10:39 AM
Network Native
Danglerb's Avatar
Maybe a quick trip to the coin car wash.
Old 05-26-2008, 10:53 AM
MPDano's Avatar
Thanks Roger for that info.
I just dropped my Tank at El Cajon Radiator here in San Diego. $65 and a guarantee that it will look like new. We'll see tomorrow.
Old 05-26-2008, 12:42 PM
Heavy Metal Relocator
rhjames's Avatar
I suppose your planning on this:
be sure to replace all of the hoses before everything goes back together.....
--Russ
Old 05-26-2008, 02:28 PM
MPDano's Avatar
--Russ
Yes sir! They are just there for me to get the correct size.
Old 05-26-2008, 04:07 PM
