MPDano's Avatar
Purolator Filter inside Gas Tank?
Hi all!
I finally took my gas tank out of my 81 Euro 4.5 and was in the process of cleaning out the gunk when I removed the part that screws into the tank (part that connects to the fuel pump) and on the inside there is a Purolator Filter (part # PM 4199). Anyone know more of this? I can't seem to seperate it from the assembly. Where can I find a replacement or should I just clean this one?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-25-2008, 07:22 PM
Heavy Metal Relocator
rhjames's Avatar
pelican parts or the other three..?
--R
Old 05-25-2008, 07:59 PM
Network Native
Danglerb's Avatar
Which one, the in tank screen or inline by the pump.
928-110-147-09-M67 Fuel Filter, 928 (1978-79)
928-110-253-06-M67 Fuel Filter KL-21, 928 (1980-95)
928-201-081-03-OEM Fuel Filter Screen, (in tank), 928 (1978)
928-201-081-04-OEM Fuel Filter Screen, (in tank), 928 (1978-88)
Old 05-25-2008, 09:11 PM
MPDano's Avatar
The one inside the tank (screen). Yikes, $53! Mine seems to be fine but needs a cleaning. How do you seperate it? I will take a pic of it.
Old 05-26-2008, 06:10 AM
MPDano's Avatar
Old 05-26-2008, 06:33 AM
rjm65's Avatar
Arrows point to the hose clamps. Let me know the size and I can check to see if I have any laying around at work that size. If you undo those clamps, does everything from there on down look like one piece?
Old 05-26-2008, 07:25 AM
MPDano's Avatar
Thats the question Raymond. I am not sure since I don't have a reference pic of the screen filter by itself.
Old 05-26-2008, 07:34 AM
The filter is part of the pump assembly and as far as I know is not a seperate part.
The intank pump 928 608 013 00 is $142.99. As far as ROW PET fitted until 79 though I have seen them in later cars.
If the pump is running well with no noise I would clean the existing pump.
Run it backwards as well to release any crud.
www.************
Old 05-26-2008, 08:11 AM
MPDano's Avatar
Ah, so the whole deal is a pump assembly. Makes sense since it wont come apart. I wonder why they needed 2 pumps to get fuel to the engine.
Old 05-26-2008, 08:55 AM
Usually if the external pump starts playing up then the internal is toast.
In your case it looks OK but only you will know by running it. It should be smooth and just have a low pitched hum.
www.************
Old 05-26-2008, 09:05 AM
MPDano's Avatar
Thanks Rog. I'll check it out in a few. Normal 12V, correct?
Old 05-26-2008, 09:32 AM
Network Native
Danglerb's Avatar
Easy guess why the intank pump might be found on some newer 928's, used tanks.
Here is a pict of just the screen on a pumpless.
Old 05-26-2008, 09:40 AM
MPDano's Avatar
The tank in my 81 928 had yellow writing like you see on used parts. Maybe my 928 doesn't need this in tank pump. What year did the in tank pumps start being included?
Old 05-26-2008, 09:48 AM
Network Native
Danglerb's Avatar
If you have a pump, and it works, use it, if it doesn't I would try a screen and skip the pump.
Old 05-26-2008, 09:52 AM
