Porsche Crest Repainting my 1984 928stt
I am striping and repainting my 1984 928s tt, I have all the fenders striped and doors striped and the hood, I just painted the under side of the hood today with waterbase 90 line (BASF) , Ill post pics soon.
The beast 1984 928s twin turbo 5speed LSD/ 508.6RWHP 495RW ft lbs 12.5 psig manifold pressure, MS2 and EDIS-8 nikasil block JE 2618 pistons (TripleT). 2001 AUDI A6 4.2 chip 320 hp. 2002 CHEV Tahoe 4wd. 1971 sonett race car GT4 National Champion now GTL class car sold. The words of a Ford GT man. ( Damit i need to get some turbos)
Old 05-05-2008, 11:23 AM
Old 928 Guy
surfdog4's Avatar
What are you using to strip the paint? Aircraft Coating Remover? I'm facing that job with my '81
1990 C2 Cabriolet Guards Red
'81 928 Zinnmetallic Project Car (sold) )
'87 944na Maraschino Red Metallic (sold) )
Old 05-06-2008, 09:49 AM
Yes Aircraft striper it is about $23.00 dollars a gallon
Old 05-06-2008, 11:53 AM
Freiherr
Red Baron's Avatar
What color are you repainting the car?
Old 05-06-2008, 04:35 PM
It is milan red met paint code is 811
Old 05-06-2008, 05:48 PM
Heavy Metal Relocator
rhjames's Avatar
using a chemical stripper may be quicker, but you have environmental concerns and "other" parts to keep the stripper away from.....not to mention for some of us it's just plain messy (so is sanding, but at least you can sweep it up).
of course, your other alternative is sanding (grinding in my case), but it just depends on how much labor you want to put into it.
it took me approx 15 hours to strip the paint (12 coats) off my Euro. I basically did one section per day.....with a 36 grit paper. yes, that's pretty coarse, and it will leave grinding marks----to be filled with several coats of filler primer. take care to not let the grinder/sander heat the metal----keep it moving all the time.
be sure to wear a mask and goggles if you do the grinder/sander route---rubber gloves if you go the chemical route. also, don't do either of these in an enclosed area.....
I have approx 30 hours in paint removal, parts removal, interior removal----just to get it to the point of being ready for body work (rust repair, welding the holes [rub strips, marker lights, rear wiper, antennae], installing Louie Ott Nizzzazzz fenders, etc), then comes numerous filler primer coats--block sanding each and letting each of them breathe for weeks on end--, and then paint. Then it's on to putting the car back together--this may involve many more hours because you have to be careful not to damage the newly painted pieces.
On the other hand, Dad sanded his down to the metal, masked it himself, and then had a pro spray it. He did his entire paint project for less than $600 including paint, materials, and labor. (It does not include his labor..... )
--R
Old 05-06-2008, 07:52 PM
Network Native
Danglerb's Avatar
I'm thinking with a black car other than fixing a few rust spots I would "polish" off the added layers of paint, and aim for a light coat over as much of the factory paint as I could.
Old 05-06-2008, 10:13 PM
MPDano's Avatar
What do you use to strip the bumpers since they are plastic?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-07-2008, 05:54 AM
rhjames's Avatar
for the rubberized parts (front and rear bumper, headlight covers) you can sand off the paint. it is something to take care doing, just don't go after it with a grinder. if you are lucky and don't have 12 coats of paint to remove (like mine), you can do this with a 120-180 grit paper. I used a palm sander with 120 grit paper on the headlight covers, and it took about 30 minutes per cover.
an easier way is to locate a shop that uses a media blaster--walnut shells comes to mind....quicker, environmentally friendly----less labor.
--R
Old 05-07-2008, 09:50 AM
MPDano's Avatar
Hi Russ,
What is a palm sander? Is this electric or that rubber block? Is this how you removed your paint from you bumpers? Also, whats the hps on your car? Is it painted yet?
Old 05-07-2008, 11:00 AM
There is bumper striper out there for bumpers only, or just sand it off but you then have to sand smooth the little bumper fibers from the plastic bumper that you get from sanding the bumper with 180 or 220 grit.
Old 05-07-2008, 11:44 AM
Hey rhjames are you going to paint the hood, doors,hatch ect off so there is no tape lines and over spray .
Old 05-07-2008, 11:47 AM
MPDano's Avatar
Will this work?
Bulldog Flexible Bumper Stripper by Klean-Strip, is a paint remover designed for flexible parts. If you follow instructions, you’ll be able to strip any flexible bumper regardless of composition. Urethane parts survive the stripping unharmed, even if the OEM coating is a two-part epoxy. Two more pieces of good news: Bulldog Stripper comes in a handy spray can, and it stays put...even on vertical surfaces. So far, so good, but how do you force that bumper to take (and keep) paint? Let’s take the next step in preparation: again, leaning on Klean-Strip for the answer.
Old 05-07-2008, 12:31 PM
Will this work?
You need to follow the paint line that you are use to prepare the rare bumper for primer ( Dupont it is clean first with 2320s then sand then use 2330s one coat let flash 15 min then put on your primer)
Old 05-07-2008, 01:39 PM
MPDano's Avatar
Whats a 2320s and 2330s?
Old 05-07-2008, 02:34 PM
Cleaner and adhesion promoter, respectively.
Old 05-07-2008, 02:44 PM
MPDano's Avatar
Sorry sonnet3 for the hijack. Any special primer, or does normal primer flex? Thanks Glen!
Old 05-07-2008, 07:23 PM
Network Native
Danglerb's Avatar
Leo, you have to follow whatever directions for the specific paint you plan to use. This is why you need to find a paint guy that knows the paint. The places that sell the paint "may" know the recommended procedures for the products they sell, but I would rather trust the guy that is going to spray it on. He is the one whose feet I would hold to the fire for results.
Old 05-07-2008, 09:41 PM
If you are striping it to bare metal then you neeb to use any primer that it direct to metal like dp26, dp25 ,dp27 in (BASF0.
Old 05-08-2008, 03:46 AM
MPDano's Avatar
I am still talking about the rubber bumper material. Reason being, I want to prep it myself before taking it to a pro painter. Since I never painted a rubber part, I know the actual paint requires Flex Agent, but what about the Primer?
Old 05-08-2008, 05:30 AM
