Network Native
Danglerb's Avatar
OB knock detection
I'm going to have the body of my intake off soon to rework the vacuum lines on my 84 Euro motor, and I am thinking "while I'm already in there" maybe I should put in a couple knock detector things even if they are only used during shark tuning and even then via some aftermarket box.
Any suggestions on which knock detection devices and/or box to use them with?
Old 08-29-2008, 06:52 PM
lizard928s's Avatar
do a search on google for knock lite.
Old 08-29-2008, 07:06 PM
http://www.jandssafeguard.com/VampirePage/J%26S_Vampire.html
Louis Ott
'90GT, 6.5L 585hp/535tq (NA)
'91 GT (in rehab)
'79 5 spd (mostly dead)
Old 08-29-2008, 10:27 PM
inventor
porken's Avatar
Up to 86.5, there is only room for one knock sensor, at the front. You'll need a used S4 plug to mount it. (AFAIK, noone has found a part number for it new.)
I used a KnockLite for the display. I also made a automatic retard using the KnockLite's 5v low output.
After all this, I find that S3s are highly resistant to knocking.
POWERED BY PORKEN
1986 928S3 AT grandprixweiß weinrot #1195
1988 928S4 MT polarsilberm sw/grau #1023
liftbars.com porken.com S300s.com
Old 08-29-2008, 11:34 PM
Network Native
Danglerb's Avatar
Something like one of these as the sensor?
0261231036 Bosch 1995 VW Golf
Knock Sensor/Detonation Sensor; 520mm with Blue Plug Connector $42.48?
Old 08-30-2008, 01:14 AM
So this vampire system will work off of a single knock sensor, like what Porken installed in his?
I have an S4 plug and knock sensor to put on my engine, how would this system integrate with the LH2.2 & EZ-F brains using the sharktuner?
Heidi... '86 928S #0223 {Isoch} Garnet Red Metallic/Burgundy (crispy)
Helmut '86 928S #1396 {Droop} Guards Red/Slate Gray
Beth.. '86 928S #2641 {Isoch} Garnet Red Metallic/Burgundy Stage III Supershark Nearing 500HP
Zelda.. '86 928S #2698 {Droop} Meteor Metallic/Burgundy
Old 08-30-2008, 12:17 PM
DanielDudley's Avatar
You are the man, Porken. Do you ever tune cars for money ?
Old 08-30-2008, 01:09 PM
Network Native
Danglerb's Avatar
http://www.liftbars.com/phpbb3/viewtopic.php?f=14&t=35&sid=ae77b88597f366bf65bd4fb041a21f9f
Old 08-30-2008, 02:21 PM
inventor
porken's Avatar
Any Bosch sensor will work. I used an S4 sensor because the pigtail keeps the connection out of the muck. Because I have the auto retard circuit, I didn't need the EZ-F air temp sensor, so I reused it's wires to the EZ-F for the sensor.
I have since reduced the KnockLite sensitivity to 11 (1 is most sensitive). On the dyno, I unplug it.
The Vampire can retard individual cylinders, whereas my DIY circuit can only retard all the cylinders using the octane loop.
thread
That would be work!
POWERED BY PORKEN
Old 08-30-2008, 03:09 PM
