Proper use of gasket sealant
Some of you may not know how versatile gasket sealant can be, so here are a few picks of the US 85 motor I just bought.
http://forums.pelicanparts.com/uploa...1219904406.jpg This shows the benefits of liberal use of lithium grease. http://forums.pelicanparts.com/uploa...1219904458.jpg Many may not realize that sufficient sealant easily replaces a thermostat. http://forums.pelicanparts.com/uploa...1219904511.jpg Tomorrow the TB and heads come off, oh joy. ;) |
If sealant won't work then JB Weld certainly will :D
(don't forget to get your "bonded rubber buffers" for that throttle body!..just got word mine are on the way) |
Using just enough is the sign of a pro.
http://forums.pelicanparts.com/uploa...1219983681.jpg An automotive artist always works with a full pallet. http://forums.pelicanparts.com/uploa...1219983759.jpg Maybe JBweld is best, but look what RTV can do. http://forums.pelicanparts.com/uploa...1219983843.jpg Sealing the bearing oil hole not such a good idea. http://forums.pelicanparts.com/uploa...1219983914.jpg |
As if the poorly rattle can'd yellow valve covers didn't give you an idea of what's inside....
And they did so well painting the valves ...
http://forums.pelicanparts.com/uploa...1219984328.jpg |
They painted the valves? WTF?
That should all buff right out. |
Looks like what they taught me in autoshop in h.s., upper east tennessee. Didn't know we were really producing mountain crafts at the same time. Kind of autoshop/art appreciation.
You must have gotten a pretty good deal, else needed something on that block pretty badly... |
| All times are GMT -8. The time now is 08:18 AM. |
